Cool down after a hard drive?
Originally Posted by speedygp
I'm sorry but I am going to have to disagree with you!! You are so wrong.
The only reason you let a turbo cool down is so the oil gets back down to normal operating temps. Period! Like posted earlier most new turbos are water and oil cooled from the factory to prevent the oil from coking up after a hard drive. Even so I always put a turbo timer on all my FI cars becuase they are such cheap insurance!( $99 for a TT )
^^^^I'm sorry but I am going to have to disagree with you!! You are so wrong.
Originally Posted by glennp_1999
Which is incorrect you still need to cool down an NA engine after hot laps. This is common practice when tracking your car it does NOT ONLY APPLY to turbo engines.
And you should take a cool down lap to cool the brakes, even if you do not pull the e-brake. The pads remain in slight contact with the rotor and that area of the rotor will not be exposed to ambient air and may cause uneven cooling.
It's just an electronic device that leaves your motor running for a set amount of time after you take the key out of the car. Allows you to be able to cool your turbo without having to sit in the car and wait.
Originally Posted by CKwik
Based on what? What ill effects will occur on a NA motor? A healthy motor should run within a safe temperature range. I was in a bit of a rush when I posted originally in this thread, but I should clarify that by cooling down, I am referring to running a cool down lap where you are not loading up the motor nor the brakes. This should allow the brake temps to drop sufficiently, and if for whatever reason your motor is running hot, it will likely cool down to normal operating temperature by the end of the lap. Either way a rapid shut down of a NA motor after a hot lap will have no ill effects unless the engine is actually overheating(so long as the overheating is from a lack of cooling capacity as opposed to a loss of coolant or cooling system failure). And if a failure is a cause of excess heat, the only way to cool the motor will likely be to turn the motor off.
AFAIK, cool down laps are more to cool the brakes than anything else. Speaking of which, I just cooked my rear brakepads at Mosport today and I'm done for the weekend. I have a spare set of fronts on hand, but never expected to go through a set of rears this fast.
Doing a cool down lap is good for the car don't get me wrong. A cool down lap is sometimes not enough to cool all the components of an engine after a several hot laps around the track. If you think I'm wrong then so be it then I'm wrong. Remember not all engines that do hot laps on the track are always healthy. Any engine expose to this kinds of conditions will need all the help it can get. It can shorthen an engines life by not doing a little preventive measures. Show me any metal that doesn't fatigue, warp or crack under exessive heat then I just might believe your analogy. Do what you wish shut your engine down after hard driving it's not my engine. After all I don't know what I'm talking about and I base all these theory out of nothing. Goodluck with your engines people.
But I'll tell you what, if you think you know what you are talking about and have some theory about it, then by all means, explain it.
