G coupe - reserve tank?
Old Jul 5, 2005 | 02:04 PM
player's Avatar
anyone know if we have a reserve in the gas tank? i heard after the needle hits the E, we still have about 40miles of gas left, just checking to make sure
Old Jul 5, 2005 | 02:09 PM
1BADV6's Avatar
I pray I never have to find out.
Running low on gas is like sipping a spilled milkshake off the kitchen floor--might still work but you're gonna eat some grime.
Old Jul 5, 2005 | 02:15 PM
Diesel1's Avatar
Moderator
There is no reserve tank, the G isn't a motorcycle....LOL. When the Low Fuel indicator comes on, we have about 3 gallons or so left. Again, as stated above, it's not good for any car to run a tank that low!
Old Jul 5, 2005 | 02:17 PM
player's Avatar
hmm didnt know this, what am i missing, why is it bad for you?
Old Jul 5, 2005 | 02:26 PM
mrb's Avatar
mrb
I've owned many bikes and they don't have reserves, per say, either
Since FI was introduced on the 98VFR800, they just have a light that comes on indicating X amount of fuel left, same way the car works. I do remember the petcock and reserve booshiat of bikes from yesteryear though
Old Jul 5, 2005 | 02:27 PM
madchef's Avatar
What he is referring to is probably that some BMW's have a reserve tank, incase you run too low.
But as far as I am aware, there is no reserve tank. So far I have run below the E a few times, and the closest I have ever come to empty is 18 gallons/20 gallons (still had 40 miles to go)
It probabaly varies from coupe to coupe, but I would estimate that you have around 5 gallons left when you hit E (or approx ~100 miles)
Old Jul 5, 2005 | 03:09 PM
heeb's Avatar
You know how when you fill the tank up, the needle goes way past the F mark? Thats how much it goes past the E mark as well, so keep that in mind. I try to let mine go all the way to the E before I fill it up, and the most I have ever put into it ever is 17.5 gallons, so that means I have well over 50+ miles I could have travelled, but of course I like to play it safe.
Old Jul 5, 2005 | 03:18 PM
1BADV6's Avatar
It is bad because
1) Uneven pull of fuel causing it to run worse
2) Sediment is more likely to be pulled on a low tank
3) Sediment=bad
Yes we have fuel filters and blah blah blah, but why run low and clog/ruin the filter when stopping to get gas at a 1/4 tank is just as easy?
Old Jul 5, 2005 | 03:52 PM
KAHBOOM's Avatar
I can't fill mine up past the F- I can get just short of the F- in fact just above the line before the "F". As soon as my fuel light comes on (just above the line before the "E"- almost touching it) I can normally place 16.5 gallons in it or so. I wonder if my fuel gage is off or if it is not filling all the way up.
Old Jul 5, 2005 | 03:58 PM
D87's Avatar
D87
The reserve tank is located right next to the Dilithium Crystals Panel.
Old Jul 5, 2005 | 04:12 PM
damonb10's Avatar
Is the Dilithium Crystals Panel behind the Flux Capacitor? I can't seem to find it.
Old Jul 5, 2005 | 04:17 PM
SDG35619's Avatar
no its over by the Continuoum Transfunctioner.
Old Jul 5, 2005 | 04:21 PM
Repsol's Avatar
3 Gallons left when I reaches the E? Wow, that seems like a lot to have left, in my old car when the light came on I only had around 1.5 to 1 gallon left in the tank.
Old Jul 5, 2005 | 04:31 PM
accordfreak's Avatar
max i drove with the light on was about 50 miles..
Old Jul 5, 2005 | 07:27 PM
csdstudio's Avatar
The fuel pickup is at the bottom of the tank anyways. With a full or empty tank you would pick up contaminents just the same.
