Sterring wheel alignment
Old Jul 15, 2005 | 12:14 AM
Hockeyplay95's Avatar
This may sound like a dumb question, but I'm going to fire away anyway. I just got my exhaust/headers/cats installed today but when I got it back i noticed something different. The steering wheel wasn't aligned (meaning the Infiniti logo isn't straight-up-and-down, its tilted about 25 degrees to the left). The car is fine in its self, still drives straight its just when the car is in a straight path the wheel is supposed to be straight up and down (like this: ||). However, when the car is driving straight the wheel is titled to the left and not square (like this: \\). Whats the problem, and is there some way to fix this? If it can be fixed, is it hard to do? I guess I'll call the shop tomorrow and try and get them to fix it, but they are pretty far away. The dealer is a lot closer--could this be fixed under warrenty? I know its not a big deal, but it bothers me and i want it fixed!
Hockeyplay95
Old Jul 15, 2005 | 12:27 AM
Here is a pic of what i am talking about: When the car is driving in a straight path, the wheel looks like this--
csdstudio's Avatar
Hockeyplay95
Header install. When they reattached the steering shaft, they didn't line it up correctly. One of those things that should be marked prior to removal.
Not a big deal? I would be annoyed if mine was off 2 degrees, let alone 25 or so.
Old Jul 15, 2005 | 12:29 AM
Ahh ok, so is it easy to fix? I guess i'll call them tomorrow and they can fix it.
Hockeyplay95
Old Jul 15, 2005 | 12:31 AM
csdstudio's Avatar
Depending on how hard it is to access the steering column. But, it is there fault, so they should fix it.
Old Jul 15, 2005 | 12:45 AM
Ok, any idea on how it is fixed? Like, i know the steering shaft needs to be readjusted, but is there a set mark for where it is supposed to be, or are they going to have to keep readjusting it until its right? Meaning, they adjust it a little bit, put it back together, i take it out for a test drive, take it back, readjust, put it back together, test drive etc.? Is it something that can be done in like 10 minutes or is it going to take like 3 hours? Now i'm heated, b/c of the maintanance guy even drove the car around to the front, so I'm sure he noticed and just didn't say anything.
Thanks,
Hockeyplay95
Old Jul 15, 2005 | 01:28 AM
any ideas?
Hockeyplay95
Old Jul 15, 2005 | 01:29 AM
csdstudio's Avatar
He probably didn't notice, wouldn't unless he was cruising around for a while and happened to look down at the wheel. Don't know if its splined or not. Maybe they are one spline off. Or if its just a matter of loosening a couple of bolts, shift a few degrees then tighten again. Can't be too difficult.
Old Jul 15, 2005 | 01:31 AM
csdstudio's Avatar
BTW, review your mods. What do you think? Noticeable difference?
Old Jul 15, 2005 | 10:55 AM
Well, I haven't been really able to drive it (worried about the steering wheel), and I just reset the ECU last night, so I can tell you after I drive it today. Is it bad to drive the car with the steering wheel like that?
Hockeyplay95
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
