Question about 6MT shifting.
Old Jul 21, 2005 | 11:35 AM
csdstudio's Avatar
While driving normal, clutch-shift-clutch, when I shift into second I feel two notches, doesn't go right in but stops for a second half way and then goes in all the way. Is this normal? I feel it in third sometimes, but now always. Not sure how else to describe this. Hope it makes sense Seems more noticeable if I shift faster.
This is my second manual car, so I do know how to drive it. But who's not to say I'm driving it incorrectly, lazy clutching perhaps? 6K miles, and I think its been doing this since day one.
Old Jul 21, 2005 | 11:42 AM
TheKnite's Avatar
G35
Search for other threads, but it is very common. I have the same problem, although 2nd gear hardly ever does it anymore. Third I feel it a lot, although when I press the clutch and slowly shift from 2nd to 3rd it is smooth. I mentioned it to the dealer and said it's normal.
Old Jul 21, 2005 | 11:48 AM
Gee Im Fast's Avatar
Yes it's normal, hence the term "notchy" that you'll see on these boards when describing the gates on your gear box.
Old Jul 21, 2005 | 01:05 PM
kenchan's Avatar
once the tranny oil is warmed up and you get the timing right on the throttle roll off
and clutch-in, you won't feel the knotch any more.
Old Jul 21, 2005 | 01:17 PM
art scott's Avatar
I think what you're feeling are the detents for 1 st, neutral, 2 nd and 3 rd gears.
My 6 MT with 1200 miles still has it.
art
Old Jul 21, 2005 | 01:20 PM
csdstudio's Avatar
That's what notchy means? then yes notchy. I guess I have read many other people mentioning the same "notchy" feeling. I just wanted to make sure it wasn't because I sometimes don't completely clutch to the floor, more sorta lazy/smooth sometimes. Zero grinding of course, I'm not that lazy.
Old Jul 21, 2005 | 01:37 PM
madchef's Avatar
What you are feeling is normal. It's because you are trying to "shift faster".
The syncro's will do their thing, regardless of how fast you try to shift. So if you are trying to shift too fast (fast n furious style), you will feel the slight delay.
Moral: find the right timing (how fast you can shift, without a delay), and be gental
Old Jul 21, 2005 | 03:36 PM
csdstudio's Avatar
I've slowed my shifts down, but then feels like I'm riding with my grandma and her slow shifting BTW, the synchros should be covered up to 60K anyways right. Now that I think about it, I had to have my tranny replaced at 40K in my MT galant. Maybe that was because I would go around corners, redline it, and then drop the clutch in second. Not sure tho....
Old Jul 21, 2005 | 04:20 PM
csdstudio's Avatar
Originally Posted by clinty
Replaced tranny? I didn't think they would do that just because of a few synchros. Maybe your main bearings and a few other pieces needed work.
Hmm...wonder if towing around my old jetski had anything to do with it. Before it crapped out completely it locked up in 3rd, now THAT was an interesting drive home.
Th611
Oct 27, 2015 03:48 PM
RA081024
Aug 18, 2015 07:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nervseele
Jul 17, 2015 11:21 PM
