XM Radio: Aftermarket or factory?
Old Aug 9, 2005 | 04:02 PM
BocaCoupe's Avatar
G's Up, Ho's Down
I'm picking up my coupe tonight without XM unfortunately. Its a lease so i probably wont be changing the radio. I wanted to add XM and was either thinking a nice removable unit or getting the OEM xm reciever.
Are there any kits for adding an aftermarket xm reciever to the G35 without using a tape or radio based adapter? What are you guys using for sat radio?
Old Aug 9, 2005 | 05:07 PM
truplay8's Avatar
THE BATMOBILE
where in boca do you live??
Old Aug 10, 2005 | 09:22 AM
05Scoobyroo's Avatar
My coupe didn't come with XM either, its best to order the OEM Infiniti XM Radio kit. I ordered mine from EverythingG35.com. Came in under $400. It took me about 1 hour to install (being extremely cautious around the trunk seal). I just don't like the fact of adding an XM kit that has to mount somewhere inside the cabin, to me it means more things to get broken. Plus the OEM integrates with the factory radio flawlessly.
Old Aug 10, 2005 | 05:29 PM
Beowulf's Avatar
You pretty much have to use the OEM radios unless you want to upgrade the entire HU, but the good news is its not hard to do yourself (under 1 hour) for a rear deck install.
Old Aug 10, 2005 | 05:41 PM
Texasscout's Avatar
The only disadvantage is the limited amount of information you can display on the factory head unit. You can't even make it scroll! But, it's still the best way to do it because, there is little room to mount an after market unit.
Old Aug 10, 2005 | 07:09 PM
MikeStarrG35's Avatar
Obsessive Owner
Factory is the way to go. The display isnt the best, but its probably the cheapest and you wont have to mount a XM unit somewhere in the cabin or replace the headunit.
Old Aug 10, 2005 | 08:40 PM
Jtrain's Avatar
OEM is amazing- I'm in Great West Palm, We've had some KILLER storms and the XM was crystal. And the Jazz stations are great (Station 70, "Real Jazz")
48 Squizz rocks to =D
Old Aug 10, 2005 | 08:43 PM
suzook's Avatar
i actually put my roady2 in the cubby(i dont have nav)when you flip open the cubby it is mounted on the door.when you want it out of sight you just close the door.i also used the pac aux input adapter.it sounds and looks great.i will post a pic when i get a chance.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
