Baseline Dyno Results
Old Aug 11, 2005 | 10:22 AM
shawn7's Avatar
03 6sp MT
85.97 Degrees
69% Humidity
Max HP = 236.21
Max Torque = 220.83
Once I do some basic mods I'll run again and see what I gain.
~Shawn
Old Aug 11, 2005 | 10:25 AM
neffster's Avatar
Where is all of the data? There are about 100 important data points and you only gave us one of them.
When doing mods you'll need to compare area under the curves to see if/where you make/lose power.
Old Aug 11, 2005 | 10:56 AM
shawn7's Avatar
Help a brotha out
I'm new to this Dyno business.. That is all that is on the sheet he printed out. It was done in SAE.
I started out at about 1500 rpm in 3rd and redlined it.
~Shawn
Old Aug 11, 2005 | 11:30 AM
Pepper's Avatar
Shouldnt a dyno run be done in 4th gear for the correct gear ratio???
Old Aug 11, 2005 | 11:32 AM
QuadCam's Avatar
actually, 5th gear is the best for a 6mt. Our 5th gear is 1:1.
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
