Navigation LCD , SAT and left speaker out Qs...
Old Aug 17, 2005 | 12:38 PM
kb9coupe's Avatar
Lately, I noticed that my LCD needs 5 seconds or so for it to get to its normal brightness. Scenario: I get in, start the engine, pop up the nav, screen is very dark, I need to wait 5 sec so I can clearly see all the lettering . Is it normal?
My Sirius SAT tuner used to "freeze" from time to time (first it would say ACQUIRING then NO SAT ) , disconnecting tuner or battery would help. Lately this has not happened (more then couple months). Am I lucky or has the Sirius signal changed a bit to prevent tuners from freezing ( from what I'm told... ) ?
Also from time to time when switching from SAT to CD my left front speaker stops working. I need to restart the car/play with radio controls to fix this... Is this common ? Is there a TSB/fix for this ?
kb9coupe
Old Aug 17, 2005 | 12:50 PM
allforthecash's Avatar
When the LCD for the nav is dark is the weather cold? Or Is this temp independent? In my previous cars when the temp was cold or hot hotside the nav screen would be darker/unclear and then when normal operating temperatures were reached it was fine....
Old Aug 17, 2005 | 12:58 PM
kb9coupe's Avatar
I don't think its temp dependent... We are in the middle of August and its pretty worm outside...
I had same problem this morning...
kb9coupe
Old Aug 17, 2005 | 01:00 PM
D87's Avatar
D87
kb9coupe
I never considered worms pretty but ok...
Old Aug 17, 2005 | 01:14 PM
kb9coupe
IF i remember correctly my LCD in the past would be darker on hot days.....and on the cold days it would be brighter than usually.....
Did You talk to the dealer about this problem?
Old Aug 17, 2005 | 05:12 PM
Msedanman's Avatar
O.F. Administrator
kb9coupe
Up here in the frozen north (UGGGG) my navi is dark(er) until warmed properly, but in the summer months, all my navis (Sedan, Coupe and now the M's) comes up legible very quickly.
I'd say you have some issues with your system.....could be BCM related.
Dealer time.....G/L
C.
Old Nov 13, 2005 | 11:54 AM
nchuiy's Avatar
left speaker problem
I seem to be having the same problem as you with respect to the left speaker. It does on and off (or it's really weak!). Apparently it's a known problem. I will let you know what the dealership says. ( I will be going soon)
Thebaws11
Jul 2, 2021 11:36 AM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Mikesta
Audio/Video/Electronics
Sep 10, 2015 05:14 PM
