Audio Project
Guest
Posts: n/a
Re: Audio Project
Hey G35MT,
How do you know there was a conflict with the stereo? Maybe when you tried the A/C, the car was not on (to have cold air) I am trying to think of a copuple explanations. How would you be able to tweak the A?C not to depend on the casette player ?
Re: Audio Project
I believe the reason the A/C dies, and the VDC, TCS, whatever else there may be that doesn't function correctly, is becuase the stock stereo and casset player are used for grounding sources and power is passed through the casset player, so when it is disconnected, the circuit is broken and the devices that are dependent on this signal wont work until the circuit is completed.
Maybe infiniti used the cassette player for a 12v signal source to turn these devices on instead of routing it to the fuse box.
Re: Audio Project
Zaid,
I turn on the ac for at least 5 minutes while driving. Initially i thought same as you. But after 1 minute still produce heat only. Then i waited for awhile until 4-5 minutes, i couldn't take the heat and just turn it off. But after putting the factory stereo back, then i turn on the AC, within 5 seconds, cold air start pumping in. Take out the radio again, perform the same test, only hot air come in. So i know for a fact that it was the radio that cause it.
The installer suggest that find which cable is need to be grounded from the radio. I am not electronic engineer therefore i wouldn't know much. Maybe some1 that have access to the service manual would able to determine it.
g35mt
g35mt
Re: Audio Project
Max,
I don't know but what you said seem to make sense. The installer mention same thing as what you said. So there might be some correlation there. I am not smart enough in this area to figure it out.
BTW, the vdc,tcs and abs light on was due to the brake switch.
g35mt
g35mt
Re: Audio Project
Jayhawk,
I had the alpine amp driving a focal set of speaker on my old car, it was okay. Then my friend ask me if i want to use his Sound Stream rubicon 604 cause he bought a Zapco competion series amp. I hook it up to the same speaker as the alpine was running. It was like night and day. The sound stream sound more dynamic and forward where the alpine was plain dull. After a month later, Soundstream went south on me so i went and bought the PG Ti 500.4. It sound better than the soundstream and it was wise purchase. I couldn't justify to pay that high for a car amp but after that experience, it was worth it. You can get some other amp that is cheaper like the Zapco reference series.
Your choice of JL 500.1 is a great one. I was gonna get that but during the installation, that amp was not available. So i chose PG 800.1 instead. But i wish that i did went with the JL. Oh well...a day late and dollar short.
G35mt
G35mt
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Nov 8, 2015 10:47 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
