Big problem in my G today
Old Aug 20, 2005 | 06:25 PM
G35lips's Avatar
Florida G35 Club Member
Well I got the news, they need to order me a new throttle body for my car. I am so pissed, they have no loaner cars and apparently the part will be in Monday night and hopefully ready on Tuesday. I am trying to get them to get me a rental car because I can not be without a car for that long. Hopefully everything will work out alright.
Lips
Old Aug 20, 2005 | 06:37 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
That damn throttle body again! Last time I was at the dealer, the service guy said that there's a TSB out for the throttle bodies, that they tend to bind or something and give poor acceleration.
Too bad you're not in Socal, I have an extra throttle body.
Old Aug 20, 2005 | 06:47 PM
G35lips's Avatar
yeah, someone else who has an 05 had the same exact thing go wrong with his car. I guess it could be worse, but still a PITA none the less.
Lips
Old Aug 27, 2005 | 06:05 PM
SoCaliG35er's Avatar
I had it a happen to me today, when I punched it. I have a moded ProFlow TB. Hmm. I will swap my stock one back. How can I repair the bad TB?
Old Aug 27, 2005 | 07:00 PM
I was thinking. Since I was in Burbank in the freaking heat(100+ F). Maybe the throttle plate expanded due to heat to the point were it seized, causing the TB to malfunction...
Old Aug 27, 2005 | 09:01 PM
E_K's Avatar
E_K
That's really weird, becuase the throttle body that went out on me was also bored out. I sent it to Proflow with a stock one, hoping that if they swapped the internals, then all would be ok, and I could keep the physically bored out one.
But that's when the ECU went into limp mode.
I've taking about the two throttle bodies, and I'm not quite sure what's going on.
I'm currently running a stock one. I have another stock one sitting at home now for backup.
Old Aug 28, 2005 | 12:18 AM
CRyan's Avatar
Yep. That was me...
https://g35driver.com/forums/showthr...&highlight=VDC
Old Aug 28, 2005 | 01:25 AM
Well I resetted the ECU, and just got back from driving the sh*t outta the TB. It's seemed ok. I think it was temperature related. I'm gonna put back the coolant connections that flows through the Crawford Plenum. I bypassed it cuz it was leaking at that time. Hopefully that will control the temperature better....
Old Aug 28, 2005 | 01:28 AM
How much is a TB these days?
Old Aug 28, 2005 | 07:21 AM
SilverII's Avatar
show $879.99 at performance nissan + 2.12 TB gasket
all that to fix a p2135 code.
I know cause I just got it fixed at the dealer under warranty
Old Aug 28, 2005 | 11:44 AM
G35lips's Avatar
Mine was $750 for the part through the dealership, but it was under warranty.
Lips
Old Aug 28, 2005 | 02:36 PM
cup0spam's Avatar
Don't sweat it, it's better it happened now than later.... Make sure to stick it to the man by doing doughnuts in the G35 sedan loaner you probably got.
Old Aug 28, 2005 | 11:47 PM
zpeedray's Avatar
My car do the same, i went to the dealer and they fixed, they told mr that it was a recall on de g35 2003 6mt models
Old Aug 29, 2005 | 04:48 PM
Per Jim at ProFlow, there was a issue with the internal gears of the throttle body. Nissan has a service bulletin for the fix.
Old Aug 29, 2005 | 05:09 PM
  #30
E_K's Avatar
E_K
I told Jim about the TSB last time I talked with him.
I've gone through about 3 throttle bodies. The internal electronics are very delicate. I didn't realize that there are electronics in the black cover. I think that's where the throttle position sensor is.
I've had throttle bodies that have unstable idle, inability to relearn idle with the pedal resets, making the ECU go into limp mode, having idles of 1500, just a bunch of crazy stuff.
My current TB idles around 750-800. Still towards the high side, but at least it's not throwing the p0507 code (high idle, more than 200 above target of 650). I had to swap a more funcational motor and electronics onto the throttle body that Jim@proflow bored out for me. Crazy stuff.
