At what psi does the Tire Pressure Light go on?
Old Sep 12, 2005 | 08:20 PM
stylez09's Avatar
I checked my tires yesterday just to see what psi they were at (TPS Sensor did NOT go off). The psi was anywhere from 29-30 on all 4 tires. I was wondering what psi these tires will need to be at before the sensor goes off in the car. I know the recommended settings are 35 psi for all, I assumed that it would go off anything lower than that...
Old Sep 12, 2005 | 08:54 PM
andychan's Avatar
Anything below 32 PSI.
Old Sep 12, 2005 | 08:56 PM
g8tor20's Avatar
FGC's official flip flopper
The manual for the 05 says that with the 18" and 19" coupe..it goes off anything below 28
Old Sep 12, 2005 | 09:00 PM
heeb's Avatar
That cant be right.
The sticker on the door reccomends 30 PSI!
Old Sep 12, 2005 | 09:13 PM
g8tor20's Avatar
sticker on my door (05 with 19") says 35 on front and rear
Old Sep 12, 2005 | 09:19 PM
DDGator's Avatar
I don't know, but 28 or lower PSI would be fine. Even a perfect tire loses air at a rate of about 1 psi per month through normal air migration. Tires are designed to carry their full load at many PSI less than the recommended pressure. I think the idea of the low pressure indicator is to inform you of a seriously low pressure condition -- even 20-25 PSI would probably be an adequate floor for that kind of warning.
Old Sep 12, 2005 | 09:30 PM
Jtrain's Avatar
Its actually when air is below a certain number yes, but when its actually loosing at to low of a rate as well.
Old Sep 12, 2005 | 10:13 PM
andychan's Avatar
Originally Posted by heeb
That cant be right.
That's what the dealership told me. My sensor went off about a week ago, and they told me that the sensor will go off if it's below 32 PSI.
Old Sep 12, 2005 | 10:39 PM
g8tor20's Avatar
Well. That settles that. Dealers are always right!
Old Sep 12, 2005 | 10:45 PM
M6_G's Avatar
Case Closed eh...
Old Sep 13, 2005 | 12:55 AM
andychan's Avatar
Not always right, but a good resource sometimes.
Old Sep 13, 2005 | 01:38 AM
Raznips's Avatar
when mine has come on (2 occasions) it has been at 32 psi. I got it checked right after it came on both times and put air in my tires after driving about 1.5 miles.... could 1.5 miles of driving raise the pressure 4psi? i doubt it...
Old Sep 13, 2005 | 05:00 AM
Strider_GTS's Avatar
Maybe that's my problem. All 4 of my tires were 32 if I remember right and my sensor has been freaking out ever sense it got colder here where I live. I suppose I'll just put more air in and see if that fixes it.
Old Sep 13, 2005 | 05:24 AM
SlvrGhost's Avatar
Mine has gone off about 7-8 times and a four or five times it's been from a slow leak, bad luck with tires. Every time it went off I checked tire pressure and it was always at 25 psi.
Old Sep 13, 2005 | 09:09 AM
tekknikal's Avatar
i dont have the esm in front of me, but i believe its 28psi
