Maintenance Engine Soon lighted?
Old Sep 26, 2005 | 05:58 PM
boe's Avatar
boe
I just hit the 1500 mile mark and the "Maintenance Engine Soon" lighted up? can somone please tell me what it is? i have no mods on my car, Thanks
Old Sep 26, 2005 | 06:41 PM
P_Diddy's Avatar
You should be able to take it to the dealership and will check it under warranty, or you could try to reset the ECU (do a search for the pedal method or leave your battery unplugged overnight) and see if the light comes back. If it doesn't come on again, you should be OK, but if it does come on, there is probably something wrong...most likely emissions related.
Old Sep 26, 2005 | 06:54 PM
boe's Avatar
boe
ok thanks, ill try that
Old Sep 26, 2005 | 07:03 PM
vjquan's Avatar
Did you just fill up the tank? A loose gas cap can also trigger the MIL lamp. If it is the cap, tighten it. After a few drives, it should shut itself off. Take it in just to be safe though. They can tell you for sure what it is.
Old Sep 26, 2005 | 08:37 PM
redwillow's Avatar
20 Year Member
you should def take it in to find out what the trouble code is. If there is a problem you need to get a record of it with the dealership. It is prob something minor, like the gas cap.....there are hundreds of codes that trigger the light.
Old Sep 27, 2005 | 09:20 AM
Beowulf's Avatar
Take it in; its not like they will charge you; if something is wrong it needs to be fixed.
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
korfak
Jul 20, 2015 12:10 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
