The Infamous Clicking?
Old Oct 7, 2005 | 07:48 AM
MikeStarrG35's Avatar
Obsessive Owner
I have noticed now that my rear suspension seems to squeek. When I get in the car in the garage it does it, if I move around alot inside the car while its in the garage I can hear the rear suspension squeek. Is this the clicking noise from the rear everyone is talking bout? I havent heard it driving at all, but I usually have my music on.
How long of a fix is this usually for the dealer? Thanks
-Mike
Old Oct 7, 2005 | 08:38 AM
giddyup69's Avatar
no, that's not the clicking noise from what i understand. the clicking noise refers to a bad wheel bearing. but let me ask u this... do u have your parking brake up when u hear the squeaks? whenever i park my car in the garage i put my parking brake up. when i exit the vehicle i sometimes hear a squeak due to the car shifting a bit from the parking brake. i usually hear the squeak from the rear driver's side.
Old Oct 7, 2005 | 09:38 AM
TheKnite's Avatar
Brake
It also seems to me like a parking brake. It's normal. The clicking noise people have issues with is when you stopped and then start driving. I wouldn't worry about your squeaks.
Old Oct 7, 2005 | 02:09 PM
DEM SUGA's Avatar
Check Axels
The clicking noise that you hear might be the axel. If it is, the stealer can fix it in under a couple of hours. I had that problem on an 05. Clicking sound when the car shifts weight going back and forth. Good luck. it should be covered under warranty though.
Old Oct 7, 2005 | 03:10 PM
Obsessive Owner
Thanks for the replies. Yes it seems to only happen when the parking brake is up. That eases my mind a little bit. Alright, thanks a lot guys.
-Mike
Old Oct 7, 2005 | 03:16 PM
jigied4lif's Avatar
hey i ve a 05 g35 6mt coupe. i seem to have the same problem but i also hear some kind of clicking noise whenever i hit 2000 rpm. sometime it continues from 2000 to 3000 rpms. i took it the dealer they said it was because of a loose under cover, but now the noise has returned. i was thinking they were jerking me cuz why would the undercover make noise only at that specific rpm points and on acceleration and decceleration.
Old Oct 7, 2005 | 05:53 PM
Obsessive Owner
Ya that sounds like BS to me, they just didnt want to deal with it. Bring it back and make them deal with it.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
