Break In Must Get on HWY for 5+ HRS, help needed.
Old Jul 18, 2003 | 03:21 PM
Deacon8700's Avatar
I am about to pick up my G35 Coupe tomorrow, but MUST drive it back home the next day. The drive is 380 miles total and I usually do it in about 6 hours (old car). What should I do to avoid damaging the break-in period? Stop every hour? Fluctuate speeds while driving? Not exceed 55? Please help me out.
Old Jul 18, 2003 | 03:53 PM
3point5SE_Auto's Avatar
Re: Break In Must Get on HWY for 5+ HRS, help needed.
drive at highway speeds in 4th (maybe if under rev limit for break in), 5th and 6th gear.
I did 700 miles the same day I picked up my car and that is what i did. better for a car to run continuously then to be shut off and heat up/cool down for short periods of time then start back up.
Use the shifter to vary RPM's if you are in traffic otherwise just vary your speed
j
I shifted about every 5-15 minutes when I was driving and did NOT use cruise.
Good luck, enjoy
Better Life thru Chemistry
Old Jul 18, 2003 | 05:34 PM
GforceI's Avatar
G SQUAD
Yeah I Did the same but be careful not using the cruise this car creeps up to 90 without warning or going past the breakin schedule. A nice State trooper was kind enough to point out my speed for me though. but the car should be fine. Goodluck!
Old Jul 19, 2003 | 02:16 PM
Deacon8700's Avatar
So should I avoid 5 and 6th gear?
Old Jul 19, 2003 | 04:13 PM
zorro's Avatar
As long as you keep it under 4,000 RPMs, the gear should not matter.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
Machine Head
Sep 4, 2015 07:22 PM
