which fuse box contains the air conditioner fuses
Nov 14, 2005 | 01:18 PM
hey
which fuse box contains the air conditioner fuses?
i dont wanna start taking things apart its not the box under the steering wheel so is it in front or behind the battery please repond guys
Reply 0
Nov 14, 2005 | 03:58 PM
not sure which, but I had to change a blown fuse a while ago. I would recommend you get the fuse puller from the inside the car fuse box (drivers side), check those fuses first, then the ones in front of the battery, then the ones behind. It's pretty easy and shouldn't take you more than a half hour to do them all. To do the ones behind the battery, you don't have to take the battery out or anything, just some of the plastic trim in that area (which only has a few screws and those pop-out things).
Reply 0
Nov 22, 2005 | 10:51 PM
Its the 10Amp fuse in the drivers left foot kick panel. Labeled "Electrical something..."
But you may have gotten it fixed by now.
Reply 0
