TPMS light on at 32/33 psi?
Old Nov 25, 2005 | 04:23 PM
jonnylaw's Avatar
Dunno if it was the cold, but my tpms light went on-then I checked 'em cold. 2 were at 33 psi and 2 at 32 psi-I have 18" oem's for my current winter setup-my q is: is that enough of a drop to have the sensor go off-is it that sensitive?
I had a set of 4 sensors put on at the dealer-so it can't be b/c the sensors aren't on (unless the dealer didn;t install them). Any suggestions besides filling up to 35 psi all around if the light doesn't turn off?
Old Nov 25, 2005 | 05:06 PM
Msedanman's Avatar
O.F. Administrator
Shouldn't OEM's be 35 psi?.. and I thought the warning came on below 30.
doulble check your pressures and see at what pressure the warning is activated. If it's still above 30, have the dealer check and adjust the system for you.
C.
Old Nov 25, 2005 | 05:11 PM
PieroG35's Avatar
Mines coming on a 32-33 psi as well. It's pissing me off.
Old Nov 25, 2005 | 05:54 PM
tekknikal's Avatar
i didnt check but the temp dropped suddenly here, from maybe 80-90 to like 60-70. i think my light went on at 32. anyway i just aired back to 34-35 and all is well again
Frankieg35
Sep 9, 2015 12:17 AM
PZ06G
Aug 27, 2015 06:11 PM
TheKnite
Aug 14, 2015 07:59 PM
joedaddy1
Jul 28, 2015 02:58 PM
