what psi to run on winter LM22 tires?
Old Dec 10, 2005 | 02:56 AM
VQdriver's Avatar
i have them on 17" Z33 rims. 235/50 and 225/50 respectively. right now i'm running 36psi. should i be running them lower when it snows hard?
Old Dec 10, 2005 | 04:45 AM
haze's Avatar
FYI, i have LM25 on, 225/40, 245/40, both 19", and i'm running 33psi front and 37 rear.
Old Dec 10, 2005 | 12:10 PM
dave's Avatar
According to the owners manual, when using 17 inch rims, the pressure should be 30 psi.
I had been using 30 psi in my 17 inch Pirelli SnowSport 210s, and the center of the tires was wearing slightly faster than the edges. This year I'm using 28 psi. That should give slightly better traction in the bad weather, and the tires should wear evenly.
Old Dec 10, 2005 | 02:31 PM
g35rcr's Avatar
i think you can check on the manufacturers website for proper inflation
Old Dec 10, 2005 | 04:41 PM
Msedanman's Avatar
O.F. Administrator
I ran 33psi front and rear in my Coupe with 17" winters. It was fine.
I wouldn't go harder than that because you'll lose contact patch.
G/L
C.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
bjo16
Aug 4, 2015 09:52 AM
joedaddy1
Jul 28, 2015 02:58 PM
multimut
Canada
Jul 26, 2015 08:43 PM
