1st Gear Issue
Old Dec 14, 2005 | 11:31 AM
xxjkimxx's Avatar
1st Gear Issue
Ssup guys.. I have 2005 G35C w/ 7200miles on it... the thing is that when my car is rolling like 2 ~ 10mph and try to put gear into 1st, its just so hard to go into 1st gear??? any idea why its doing it? is it synchro problem or am I doing or knowing something wrong?? please help~~~
Old Dec 14, 2005 | 11:35 AM
Brando's Avatar
Cool
Mine is the exact same.
Nothing wrong.....that is just the way it is.
You don't need 1st gear if you are rolling at all, only from a dead stop.
You can get it to go into 1st by rev matching if you get the hang of it.
Old Dec 14, 2005 | 11:52 AM
Espresso's Avatar
This has only happened a few times to me once it's cold out.
Old Dec 14, 2005 | 11:55 AM
xxjkimxx's Avatar
well.. same to me.... it doesn't happen all the time.. .but most of time it happens... ?? and the thing is that when you are rolling like 2 ~ 10mph and u need to move quickly, then don't you need to go into 1st, cuz if you go into 2nd and try to bust out, it won't give you much power to push out.....
Old Dec 14, 2005 | 11:58 AM
RBull's Avatar
Rated M
WHS^
I don't know why you would want to downshift at that low speed rather than acclerate in 2nd or wait until you are stopped to shift.
Old Dec 14, 2005 | 12:01 PM
trey.hutcheson's Avatar
This has been covered many, many, *many* times. It's normal. Don't worry.
Old Dec 14, 2005 | 12:52 PM
giddyup69's Avatar
+1.. i remember a fairly large thread no too long ago on this very subject matter. try running a search.
Old Dec 14, 2005 | 01:25 PM
Bigguy2000's Avatar
That's just how it is
Having drivlen M/T's off and on for 40 years let me assure you you have no problems ........ trying to match synchros into lowest gear is ike hitting a target moving too fast.
Call it naure ofl the beast.
Old Dec 14, 2005 | 01:29 PM
dartmouth01's Avatar
So is there no first gear lockout, or is this related to it?
Old Dec 14, 2005 | 01:31 PM
RBull's Avatar
Rated M
No lockout- it's normal.
Old Dec 14, 2005 | 01:42 PM
htownboy's Avatar
Don't do that, 1st. gear is way too low unless you rev match and that comes with experience but I can say I never go to first unless i'm completely stopped or very close to being stopped in all my cars & trucks and in the G I just use 2nd for those situations, there is plenty enough torque so just stay in 2nd... Been doing this since 1978.
Old Dec 14, 2005 | 02:59 PM
xxjkimxx's Avatar
so I guess everybody agreed that this is normal.. well..... if its really normal behavior that G does... then I guess I have to live with it...
BTW, thanks for the kind infos...
Old Dec 14, 2005 | 03:03 PM
Msedanman's Avatar
O.F. Administrator
Try revving it slightly next time to help the engagement.
C.
Old Dec 14, 2005 | 03:05 PM
QuadCam's Avatar
most cars don't have synchros for 1st gear downshifting!
If you need to downshift into 1st, double clutch it!
Old Dec 14, 2005 | 03:33 PM
Meeno24's Avatar
It's normal, and worse when its cold out and the fluids aren't warmed up yet. Just blip the throttle as you're downshifting and it'll slide right in.
