For those who removed the front grill
Old Dec 17, 2005 | 04:31 PM
G_Spot's Avatar
Once you get the four plastic clips off the top, how do you remove the clips from behind the grill off the bumper?
Thanx,
Chris
Old Dec 17, 2005 | 04:51 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Hey Chris...
Just finished doing my grill re&re.
1.
Right in the top corners, there are two twist clips.
They're hard to see; look from the front though the top slot. (fashlight will help)
The clips have a square head shape ;
with a slot screwdriver turn the clip 45° & pull the top of the grill towards you.
The square head will pass though a hole as the grill moves forward.
2. along the bottom there are large flat clips that mount the grill to the bumper.
reach inside & push out on them while pulling the grill forward.
The grill will pop out.
Go easy, its easy to snap them.
Old Dec 17, 2005 | 06:42 PM
G_Spot's Avatar
Originally Posted by inTgr8r
Hey Chris...
1.
Thanx for the explanation. I appreciate it.
-Chris
Old Dec 17, 2005 | 07:33 PM
avs007's Avatar
If you have problems with these clips, (like I did), try using a flat-head screwdriver. Stick it under the clip, and gently lift up. You will hear a click, as the tab unlocks. Do that to each clip, and the grill will pop out easily.
Old Dec 17, 2005 | 08:33 PM
CarFanatic56's Avatar
+1, ive had to use a flathead to help pop out those bottom clips
Old Dec 18, 2005 | 03:14 PM
G_Spot's Avatar
Thanx again
-Chris
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
TL2G35x
Aug 12, 2015 10:30 AM
realtalk21
Jul 20, 2015 09:07 AM
