Z-Tube K&N sluggish below 1.5K
Old Dec 22, 2005 | 01:08 AM
FI'ed G's Avatar
I just installed Z-Tube and K&N filter and did a reset on the ECU (05 6MT). Now it seems that when starting to move from 1st gear that i have to put more gas for it to move, it feels that it has less power now especially when making a reverse. before i dont even have to put that much gas and the car starts to move already with authority, now i have to put more gas just to have that same authority to move. Plus the sound wasn't much of a difference IMHO, atleast not much to justify a $120 worth of mod which by the way doesnt add much power either. It seems a little better when hitting the higher RPM maybe because of the ECU Reset or the Temp (around 30 deg). Any thought on 1st Gear slow start?
Old Dec 22, 2005 | 01:57 AM
Andy2434's Avatar
Hmmm . . . You make quite an interesting observation . . . Allow me to explain. I have the Z Tube/K&N combo. Some 3 months ago, I replace the K&N filter with the OEM filter for various reasons. I installed Motordyne's MREV mod some 2 months ago and everything was great. I just re-installed the K&N drop-in filter about 2 days ago. I just noticed this afternoon that 1st is alot less responsive.
This evening while driving to and from dinner, it was really noticeable. Needless to say, after I read your post . . . I took the K&N filter out and replaced it with the OEM filter, prior to responding to your post. I am curious what will develop over the next couple of days.
Old Dec 22, 2005 | 02:43 AM
99atlantic's Avatar
I was going to install my z-tube this weekend and then plenum spacer.....now i'm scared
but i have an 03 A/T, so hopefully i'll notice a better difference than you ^_^ (is it me or does it seem taht those with 05+s seem to be the ones making negative comments about replacing with a z-tube)
Old Dec 22, 2005 | 02:49 AM
Andy2434's Avatar
It's not the Z Tube that I noticed the difference with. It's the K&N filter, which has made the difference. Perhaps the K&N does not work well with my current plenum mods. I'll know in a couple of days.
Old Dec 22, 2005 | 03:12 AM
99atlantic's Avatar
i doubt a k&n would cost you power with a plenum; hell, i've seen bone stock coupes dyno +5rwhp from just adding the k&n by itself
Old Dec 22, 2005 | 03:42 AM
Andy2434's Avatar
My original post was in direct response to the original poster. I noticed the same when I replaced my OEM filter with the K&N filter just a couple of days ago. I now have replaced the K&N with the origial OEM filter. If my !st gear low end goes back to the way it was prior to the filter switch, that will be proof enough for me.
Old Dec 22, 2005 | 06:49 AM
WhiteonWheat's Avatar
Interesting. Keep us posted Please!
From what it sounds like to me, being a memeber for several months, that this car of ours just might possibly be "tuned" factory "as good as it gets" almost.
In other words, some changes/mod's might make things worse rather than better?
Anyone agree, disagree?
Just the pattern I'm beginning to see...?
Old Dec 22, 2005 | 08:55 AM
g'dup13's Avatar
pls keep us posted.. im looking to do that z tube and filter as well. but i have an 04 6spd..
as far as tuning i think ur right cause i have seen some guys with a lot of mods on there cars and they have no lie a total of jus 15 more horsepower than my stock car..
imho the spacer is the best mod for u buck.. u fee the power diff.. but im scared about warranty issues...
Old Dec 22, 2005 | 09:28 AM
RBull's Avatar
Rated M
No matter how much power you have it's never enough and you get too used to it.
We'll watch for your comments since I have the same set up.
Old Dec 22, 2005 | 09:45 AM
gqong's Avatar
hmm...maybe i will buy an OEM filter and give it a try. It has been quite a while since my k&n has been on so if there is a difference I should be able to feel it. I will update if I get around to doing this, since it is the holidays.
Old Dec 22, 2005 | 12:40 PM
MikeStarrG35's Avatar
Obsessive Owner
I would be interested to know. The MREV Plus is on the delivery truck aimed at my house, and I was going to buy the Z-tube K&N filter combo. Maybe it will just be the z-tube now.
Old Dec 22, 2005 | 01:37 PM
sngpimpin's Avatar
screw the ztube, just get a stillen CAI. if anything ive only seen positive results and feedback from the stillen intake. however i have heard the stillen and ztube are a good combo. take into account too that hes talkin about the 05 6spd for you 04 and below it could be a different case with the ztube & kn drop in.
Old Dec 22, 2005 | 04:21 PM
antdiesel3's Avatar
I had just a K&N panel filter and added a Z-tube. I definitely noticed an improvement in performance. Occasionally the rear will step out unexpectedly on the 2-3 shift if I don't have the stability control on.
Anyone know if anyone has actually dynoed these mods before and after?
Old Dec 22, 2005 | 04:35 PM
g35doc's Avatar
I have an 05 6mt with z tube/k&n and noticed no difference after install. It was the same with my 03 5at. No one should notice a difference. It's all psychosomatic since we're only talking about a couple horsepower here.
Old Dec 22, 2005 | 06:27 PM
Brando's Avatar
Wink
That is really strange.......
I installed a K&N Cone type filter on my car.....and it seems to have a LOT more power than before......
