Anyone know pin# for oxygen sensor and tachometer/rpm signal on ECU?
Old Jan 10, 2006 | 02:23 PM
evileagle's Avatar
I finally decided to hook up my air fuel gauge and window switch for the nitrous setup. But im having some difficulty finding the oxygen sensor and tachometer/rpm input wire at the ecu. I have an 05 coupe. Any help would be greatly apperciated.
thnx
Old Jan 10, 2006 | 10:52 PM
baileyrx's Avatar
pin 60,61,62 are the signals for cylinder 1,3,5
the o2 sensors are narrow band only, not worth using for their readings will not help you in your need for accurate a/f reading. Most people install a seperate sensor just before the cats.
Old Jan 11, 2006 | 03:24 PM
evileagle's Avatar
Im just using it as a safty device, not to tune with. I know these things suck, but i needed something to fill up my third pod =). Also how do you get 1 tach signal the 3 different cylinder outputs? I just need a basic tach signal for a rpm window switch.
Old Jan 18, 2006 | 02:38 AM
evileagle's Avatar
Old Jan 18, 2006 | 10:02 PM
baileyrx's Avatar
you should be able to tap into any ONE of those pins/wires. Each time the cylinder fires it'll send a signal. That should give you the accurate RPM's
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
