Gas Meter
Old Jan 18, 2006 | 01:51 AM
MrIP35's Avatar
Gas Meter
does anyone notice when you first pump gas into your car the gas gauge would be pass the first Meter where it says Full, than after a while it would be right on the first meter is this normal? Do you guys think it could be a sensor problem with the gas tank?
Old Jan 18, 2006 | 03:14 AM
richboy's Avatar
MORE POWER PLZ!!!
Mine does the same to i would like to know. How many gallons did you get i got 16g on mine.
Old Jan 18, 2006 | 07:18 AM
clifftrail's Avatar
I just had my sending unit replaced for the exact same issue and the new one operates the same. It's just that sensitive.
Old Jan 18, 2006 | 08:15 AM
giddyup69's Avatar
every car i've ever owned has had the needle go passed the full mark on fill-up. i don't see where the problem is. i would assume the reason the needle goes back down a notch after a while is because *gasp* the car is burning fuel?
Old Jan 18, 2006 | 08:26 AM
tha_kid's Avatar
I just had my combination meter(?) in the gas tank (or somethin like that...i forget the exact wording of what it was) . Mine started out like that, and after a year I could only get it to go to 3/4 tank on a full tank...Its under warranty...just take it to the dealer they'll fix you up (AND give you a free full tank of gas while their at it to make sure it works! )
Old Jan 18, 2006 | 02:36 PM
MrIP35's Avatar
thanks guys for the comments and opionins........going to the dealer this comming week.
Old Jan 18, 2006 | 03:33 PM
Msedanman's Avatar
O.F. Administrator
my Coupe had the same issue...but it came and went. Sometimes it would go to F, other times only the 3/4, yet others to above F.
I believe the issue to be the sending unit in the tank. See what the dealer will do. G/L
C.
Old Jan 18, 2006 | 07:55 PM
GRider35c's Avatar
ive had my sending units (both) replaced twice and they still went bad...
moral of the story, stop wasting your time and stop relying on your fuel gauge meter!!! refuel after every 200 miles (half a tank)... which is preferred anyhow
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
