Spinning Tires?
Old Jan 18, 2006 | 02:52 PM
e420x's Avatar
Mod Junky!
Spinning Tires?
I have an 06 6MT Coupe with the stock 19's. It seems i can only spin in 1st gear and that 2nd has a real big lag. is this normal with teh revup engines? Should I be able to spin them in 2nd as well?
Old Jan 18, 2006 | 03:28 PM
MechEE's Avatar
My 1-2 shift will hesitate due to the VDC coming on if I hit it too hard. With the VDC turned off the hesitation should go away.
Old Jan 18, 2006 | 03:53 PM
e420x's Avatar
Mod Junky!
I forgot to add this is with VDC turned off
Old Jan 18, 2006 | 04:02 PM
99atlantic's Avatar
no mechanical formula to prove how the VDC does that ^_^
Old Jan 18, 2006 | 05:08 PM
Sumlime311's Avatar
wow i didnt realize that the lose in tq in the 05-06 compared to the 03-04 realy made that much of a difference.
Old Jan 18, 2006 | 05:10 PM
Brando's Avatar
Wink
Wow.....my 03 spins them all the way thru 3rd........
Old Jan 18, 2006 | 05:22 PM
Sumlime311's Avatar
haha yes but look at the hp difference with your damn supercharger
Old Jan 18, 2006 | 05:25 PM
louielou's Avatar
hehe...yep...my supercharged nissan fronty can spin into a hopping frenzy sometimes..depending on the surface of the payment.
Old Jan 18, 2006 | 05:41 PM
MechEE's Avatar
Bahahah I love the haters! They're so cute with their little temper tantrums. Keep it comin!
Though I could give you some formulas on how the VDC does that... but you might need at least a GED to understand it!
Old Jan 18, 2006 | 05:44 PM
Brando's Avatar
You should feel it bog with the SC......
Old Jan 18, 2006 | 05:46 PM
MechEE's Avatar
Does your setup just freak out with the VDC on when flooring it in 1st, or does the VDC still work reasonably well with the SC as far as preventing wheel spin?
Old Jan 18, 2006 | 05:48 PM
Brando's Avatar
If I nail it...it freaks...but only really bad on the shift. You smash your nose on the steering wheel when it bogs.
Old Jan 18, 2006 | 06:34 PM
htownboy's Avatar
Mine too
Old Jan 18, 2006 | 06:35 PM
htownboy's Avatar
Drive by wire limitations with VDC on
Old Jan 18, 2006 | 06:49 PM
MechEE's Avatar
So with VDC off, all is well for you?
