How are you rotating tires on g35 coupe?
Old Feb 4, 2006 | 12:18 AM
Brian-g35's Avatar
only way is flip the tires inside out?
Old Feb 4, 2006 | 12:28 AM
badtziscool's Avatar
I don't think you can even do that. The tires are asymmetric. At least the bridgestones are on the 19" wheels.
Old Feb 4, 2006 | 12:32 AM
Jtrain's Avatar
You can't at all.
Old Feb 4, 2006 | 02:41 AM
alexchuang's Avatar
like it was said... you cant... up front the tires are 235 and the rears are 245... and the tires are unidirectional too... you have to take off the tires from the wheels to rotate from one side to the other
Old Feb 4, 2006 | 07:51 AM
patman530's Avatar
I believe the fronts are 225 stock and not 235
Old Feb 4, 2006 | 08:00 AM
binar's Avatar
If you unmount and remount you can rotate them side to side. Probably not worth it. I am not sure what you would gain. Front to back rotation, when you can do it, is where you gain the most.
Old Feb 4, 2006 | 09:08 AM
daveblank's Avatar
What you would gain is less tire wear. The coupe is known for inside edge wear. If you dismount/remount you would move the inside to the outside & get more life from the tires.
Old Feb 4, 2006 | 09:14 AM
BracketRacerSteve's Avatar
I've done the left/right remount rotation on the front tires, currently at 20k miles on the car and probably going to get another 10k out of the fronts.
For some reason I had to buy new rear tires at 17k miles
Old Feb 4, 2006 | 01:43 PM
Msedanman's Avatar
O.F. Administrator
That's right. Only a side to side swap is possible, but to keep the rotation the same, the tires must be dismounted and re-installed with the inside to the outside.
C.
Old Feb 4, 2006 | 01:54 PM
visualfusion's Avatar
anyone know about how much the dismount/re-install would cost about at a shop? ... I'm noticing some serious wear on my tires...
Old Feb 4, 2006 | 02:51 PM
Disco_Monkey's Avatar
15-20 bucks per tire. Some places asked for 40 per tire! =O
Old Feb 4, 2006 | 05:17 PM
... ouch!... But still cheaper than getting new tires...
Old Feb 4, 2006 | 05:54 PM
Brian-g35's Avatar
this place I'm going to tomorrow charge 12 bucks per tire...
Old Feb 4, 2006 | 08:50 PM
Dan_K's Avatar
When should you rotate your tires?
