Spring Sound
Old Aug 20, 2003 | 10:05 AM
DETCOUPE's Avatar
Spring Sound
Hey All, Does anyone else hear this sound? When I first put my vehicle in drive and begin to pull away, I hear this spring sound in the front of my coupe. Can't tell what it is, but should I be concerned?
Old Aug 20, 2003 | 11:42 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Spring Sound
Hey where in Detroit are you?
Do you have a 6spd?
That seems to be a common sound for 6MT'ers...
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 20, 2003 | 11:52 AM
DETCOUPE's Avatar
Re: Spring Sound
I'm in the Southfield area. I have an automatic. I wanted a stick, but I needed my free hand for the ladies. HA
Old Aug 20, 2003 | 12:06 PM
ryoken's Avatar
Re: Spring Sound
Probably happens right about 7mph? If you happen to be coasting downhill from a stop and have your foot resting on the brake pedal, you can probably feel it, too. It's the ABS doing a self-check.
Old Aug 20, 2003 | 12:29 PM
mchristsen's Avatar
Re: Spring Sound
I had the same creaking sound from my suspension. It would occur when the weigh would shift on the suspension (i.e. starting driving, gear change, sharp braking). The service mechanic said it was a loose bolt/nut in the linkage.
Tightened it, and all is ok. Mine started to develop after a road trip through the mountains along the West coast.
Mike.
2003 6MT Coupe Black/Graphite/Prem./Nav/Aero
1994 MR2 Turbo 5MT Black/Prem.
Old Aug 20, 2003 | 12:31 PM
RamboRami's Avatar
Re: Spring Sound
cool, i am in the farmington hills area...
The manual says that noise is the ABS checking itself...i just cant seem to believe that
Old Aug 20, 2003 | 12:35 PM
tbusguru's Avatar
Re: Spring Sound
Every morning as I pull away from my house I hear it , I also heard it from the loaner, so I guess it is a normal function as Ryoken said.
I only hear it on first take off, after that I never do.
<P ID="edit"><FONT class="small"><EM>Edited by tbusguru on 08/20/03 09:38 AM.</EM></FONT></P>
Old Aug 20, 2003 | 01:15 PM
DETCOUPE's Avatar
Re: Spring Sound
Cool thanks! I won't worry again until I don't hear it anymore.
Old Aug 20, 2003 | 02:23 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Re: Spring Sound
I think that's actually the ABS system running a startup test.
Old Aug 20, 2003 | 04:56 PM
silvsurf's Avatar
Re: Spring Sound
I had the same concern when I first got my coupe. Heard the noise as I started to pull away. Asked the service dept about this and they said it is indeed the ABS.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Albanian122
Sep 12, 2015 04:02 PM
