Part II: Guess my hp gains: Baseline dyno
Old Mar 4, 2006 | 01:06 PM
JZ39's Avatar
OK. 2004 6M/T Baseline, bone-stock dyno was done today at Altered Atmosphere during their annual G/Z meet.
Conditions:
59 degrees, 29.6 in-Hg, 6% humidity, Uncorrected
Three pulls were done. Here are the results:
HP Torque
Run 1 240.28 236.35
Run 2 238.66 260.87 (blip in the graph)
Run 3 239.91 238.11
Needless to say, I was quite happy with these numbers.
I was running pretty lean from 4000-5000 rpm initially (~16:1). They changed the sensor to a new one and I was around 15:1 on the last run.
So, these are the base numbers I am working with.
My exhaust and JWT clutch/flywheel come in on Tuesday, so by the end of next week I should have these as well as the spacer and UR pulley set in and ready for another dyno.
Once this is all done, I will consider getting the re-flash from Altered Atmosphere to finish it off.
Attached Thumbnails Part II: Guess my hp gains:  Baseline dyno-baseline-dyno.jpg
Old Mar 4, 2006 | 01:08 PM
infinite04's Avatar
nice numbers for a bone stock
Old Mar 4, 2006 | 09:10 PM
JZ39's Avatar
Thanks. I hope to put another 20-40 on it when all N/A is said and done!
Old Mar 4, 2006 | 10:32 PM
Mr_pharmD's Avatar
bone stock usually run rich. if your running 16:1, kiss your motor good bye
Old Mar 4, 2006 | 11:20 PM
g6g35's Avatar
i was there today too. What color was your G?
Old Mar 5, 2006 | 01:35 AM
truplay8's Avatar
THE BATMOBILE
great numbers
Old Mar 5, 2006 | 06:21 AM
JZ39's Avatar
I was a Diamond Graphite with a lip spoiler.
As for the A/F, on the second run after they replaced the probe, it came up at 15:1 which is not too far off from the 14.2:1 ideal.
Take a look at this A/F graph:
Attached Thumbnails Part II: Guess my hp gains:  Baseline dyno-baseline-dyno-2.jpg
Old Mar 5, 2006 | 06:22 AM
JZ39's Avatar
Do you think the lack of humidity (6%) could have had anything to do with the reading?
Nobody seemed to think there was any reason to be concerned over the ratio. They did say that their re-flash does add fuel at higher rpms.
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
