Save Gas!
Old Mar 8, 2006 | 04:25 AM
jonnylaw's Avatar
Lose weight
Old Mar 8, 2006 | 04:29 AM
Nizm0SkylineG35's Avatar
don't drive your G on days that end with y....
Old Mar 8, 2006 | 04:41 AM
Dark Genesis's Avatar
Give offereings to the G35 gods
Old Mar 8, 2006 | 10:53 AM
RebelinRI's Avatar
Geezzzzz LMAO
Old Mar 8, 2006 | 11:04 AM
aszatk01's Avatar
this has been a fun one....
well one thing you can do is the Ztube and K&N filter-if you're lucky you might see a half a mile per gallon increase. its cheap and sounds good anyways, a great beginning mod that might just give you a smidge of what you're looking for
Old Mar 8, 2006 | 11:26 AM
SilverII's Avatar
91 octane instead of 93 octane
Old Mar 8, 2006 | 12:01 PM
LTQDustx's Avatar
Have your engine removed and your car towed around by another G35 owner. That way you can still look good arriving in pair..
Old Mar 8, 2006 | 12:09 PM
JGFox's Avatar
sugar in the gas tank?
Don't really.
Last edited by JGFox; Mar 8, 2006 at 12:11 PM. Reason: helping those allergic to sarcasm
Old Mar 8, 2006 | 12:27 PM
blksnake's Avatar
Make sure your tires are properly inflated.
Old Mar 8, 2006 | 12:29 PM
CtK's Avatar
CtK
i dont think thats true
ever since i got mine ive been getting 18-19 mpg instead of 19-20 mpg
hehehe
Old Mar 8, 2006 | 01:17 PM
Keaka26's Avatar
Originally Posted by Strtsk8r321
Put it in neutral whenever you possibly can, shift at low RPMs, turn off AC, remove back seat and passenger seat to reduce weight.
Studies have shown that at speeds higher than puttering around town, the additional aerodynamic drag put on the car with the windows down will cause more detriment to your MPG than just having your AC on...Inside streets = windows down. Freeway = AC.
Also, most cars (not 100% on the G) stop firing the injectors when you are in gear and there is no throttle input. This is used to assist in deceleration. If you are coasting in neutral, there is still going to be fuel consumption. Soooo if you're coming up to a stoplight, just coast up to the light, in gear, and don't take the car out of gear until you are just about to stop. This will save you more gas than idling in neutral up to the light.
Old Mar 8, 2006 | 03:13 PM
Strtsk8r321's Avatar
Thanks for the info, but everything I said there I was joking about.
Old Mar 8, 2006 | 03:23 PM
aszatk01's Avatar
^^^over 40 miles an hour the window theory holds true (mythbusters)
under 40 it makes no difference
Old Mar 8, 2006 | 04:33 PM
Keaka26's Avatar
Ohhhh lol! Well, I thought you might be serious because when I was much younger, I would try and coast ALL the time in neutral because I was so poor. Hehe
Old Mar 11, 2006 | 12:42 AM
  #30
Well Im actually glad you said that because I didn't know that stuff, but I was just kidding about that stuff cuz it would get irritating doing that stuff all the time.
