Help in jacking up the G
Old Mar 22, 2006 | 05:52 PM
fireblade's Avatar
Red face Help in jacking up the G
This may be a dumb question, I searched already but could not fing a straight answer. OK, I know where the 4 support points are. I assume there's only one spot for the jack, so what I'm trying to figure out is, once one corner is jacked up, how do I go about replacing the jack with the stands to hold car in position?
Old Mar 22, 2006 | 05:57 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
are you trying to do this with the factory jack? if you're using a hydraulic jack then just lift the car up by the frame then put the stand under the jacking point on the pinch molding under the skirt.
or you can kill two birds with one stone and jack the car up from the frame, right behind the oil pan and then the whole front of the car will be up in the air, then throw the stands under it.
-GP-
Old Mar 22, 2006 | 06:32 PM
jersey-G's Avatar
Where else is the frame exposed along the outer edge of the car besides the jack points? I ran into this problem a few weeks ago. My hydrolic jack and stands were too wide to fit next to each other.
Old Mar 22, 2006 | 06:48 PM
fireblade's Avatar
i have jersey-g's problem. i am doing it with the facotry jack so i don't have the option of jacking it up at the other centre point. Even if I did know where it was, wouldn't help me much as i'm using the factory jack. Don't tell me I have to get a hydrolic jack just for this purpose
Old Mar 22, 2006 | 08:41 PM
P_Diddy's Avatar
if you have another jack, you can jack up the front or rear from jackpoints. See the fAQ section for threads on this. i put a diagram in there straight from the service manual. it is ok to jack it up by the differential.
Old Mar 22, 2006 | 08:43 PM
that's why you put the jack in the center on the frame and lift the whole front at once.
-GP-
Old Mar 22, 2006 | 08:44 PM
truplay8's Avatar
THE BATMOBILE
there is a thread with pics showing you where to jack it up........search it
Old Mar 22, 2006 | 09:41 PM
fireblade's Avatar
I saw that thread. Doesn't really help me unfortunately I need to jack up the front, not the rear (so jacking from rear differential would not help me). Secnldy, I only have the OEM jack and a pair of jack stands. You can't use the OEM jack at the front center location right? So basically i'm only given the 4 jack points to play with. Which brings me to the original question, how do i put the jack stands in place after i've jacked up the car?
Old Mar 28, 2006 | 12:42 PM
jimmyc13's Avatar
Fireblade - Clean Out Your Inbox So I Can Reply To Your P.m.
Old Mar 28, 2006 | 12:45 PM
jimmyc13's Avatar
Jacking the front side just behind the front tire w/ OEM jack. Jack it up and just behind the front tire, inset a little bit (at least it's on the sedan...so I presume it's on the Coupe too), there should be a steel looking hook/loop. See if the jack stand will adapt/fit w/ that; otherwise, you can just place it on the steel frame (the part that the loop/hook is connected to). Make sense?
Brando's Avatar
Cool
There is a large flat section of frame right beside the cats that works great.
gmoney1227's Avatar
Hey truplay8, just a side note I sent you a PM a few days ago... did you receive it? Thanks!
Old Mar 29, 2006 | 06:40 PM
bythabay's Avatar
Unfortunately, the G does not have a frame. Like many cars today, the G has a unibody. The only safe locations to lift the G from are the front jacking point and the rear jacking point. Afterwards, you slip in jack stands to the jack stand points (4).
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
