how to install fog lights?
Old Mar 31, 2006 | 10:45 PM
savefatkids's Avatar
i jsut got some yellow fogs but i dono how to install them is there a diy?
Old Mar 31, 2006 | 11:04 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
lol, here's my personal DIY:
https://g35driver.com/forums/body-interior-exterior-lighting-diy/86248-diy-replacing-fog-lights.html
same thing for the coupe, just a couple more nuts and clips to remove.
-GP-
Old Apr 1, 2006 | 09:05 AM
Rookie84's Avatar
BTW, you don't have to do it that way if you don't feel like removing the whole fender liner and your wheels. Just life the car a little bit(factory jack worked fine for me) with wheels turned all the way towards the opposite side you're working on, and just remove enough clips so that you can pull and bend the fender liner and access the lights. Looking at Gdup35sedan's DIY and just memorize the approximate location of where each bulb goes into. I found this to be much easier and it only took 10 min for me to do the passenger side once I did the driver's side first and gotten used to it.
Old Apr 1, 2006 | 12:15 PM
rookie.... yeah you could do it that way too, there's just some people that are less mechanically inclined so i did it the long way.
-GP-
Old Apr 1, 2006 | 12:35 PM
jersey-G's Avatar
It's A LOT easier if you just take the wheels off. Then you won't run the risk of locking them turned like I did. But if you don't take the wheels off just turn the car on before turning the wheels.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Fireman07603
Aug 9, 2015 06:00 PM
attarday
Jul 15, 2015 04:03 PM
