airbag indicator?
Old Apr 1, 2006 | 05:46 PM
04Gwhiz's Avatar
airbag indicator?
hey guys i recently removed my seats and panels(headliner and A pillar and rear pillar) to run some wires for my system..i did what i had to do and I reconnected all the wires and harnesses under the seat etc. but now my airbag light keeps flashing..is there a reset or special step I need to do?i double checked the harnesses under the seat and they are secure..is there something i am missing?
Old Apr 1, 2006 | 06:53 PM
G35 Mass's Avatar
Are you sure none of these wires you ran are in the way of your side-curtain airbags, which are stored in the roof?
At the speed they deploy, a wire whiping at you that was over the air bag could easily take of an arm or head......
Old Apr 2, 2006 | 12:06 AM
some.devil's Avatar
well if you know that there are no problems then you can reset the SRS by doing the following:
you need to put the key in the ignition and tun it to ON, then watch the airbag light. once it goes off turn the key back to off. ( make sure you swith it off before you see the airbag light begins flashing again ) Do this 3-4 times.
Old Apr 2, 2006 | 02:41 PM
04Gwhiz's Avatar
thanks..let me triple check everything b4 i do that..but thanks
Old Apr 2, 2006 | 04:14 PM
allforthecash's Avatar
was your battery disconnected before you unplugged the airbag wires??
I was always afraid of removing the seats because of this, I knew it would trip the airbag light..but wasn't sure if disconnecting the battery would prevent it.......
Old Apr 3, 2006 | 09:49 AM
04Gwhiz's Avatar
no the battery wasnt disconnected...I will let u guys know what it is later this week...
Thebaws11
Jul 2, 2021 11:36 AM
Marlin84
Apr 1, 2020 12:52 PM
vamarris
Sep 26, 2015 12:56 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
