MREV Question
Old Apr 2, 2006 | 10:29 PM
bosssho's Avatar
MREV Question
Not having the time to read for hours right now I am cheating and taking the easy way out...or so I hope at least.
I am getting an 05 left over...a new coupe...a 5AT...and I was wondering if you technically call this engine a REV UP or is that designation just for the 6MTS w/298 BHP?
Also, it's been 2 years since I needed to mod anything...and I am a little out of the loop.
Is the Crawford Plenum still the way to go or is the simple phenolic spacers I hear about the new way to go...or again, is that just for the 6MT?
Any info would be great, thanks.
Old Apr 2, 2006 | 10:34 PM
speedracerg35's Avatar
you have a rev-up engine, and i would assume most of the dirivers here would suggest you go with the motordyne mrev kit. it replaces your lower pleennum and add a 5/16th spacer.
Old Apr 2, 2006 | 10:42 PM
Andy2434's Avatar
The so-called RevUp is installed in the '05+ cars equipped with an 6MT. However, you may wish to read the following .
https://g35driver.com/forums/intake-exhaust/92810-mrev-installed-non-revup-engine.html
Old Apr 3, 2006 | 10:40 PM
bosssho's Avatar
Thanks man....I just went to the thread that andy2434 referred me to and I am even more confused. It appears all 05-06 G's have the REV up engine, but the 6 spds get better plenum air volume whereas the non 6spds get better lower plenum design which manifests itself into 10 ft/lbs more torque??? Is that correct?
Do I just need the spacer b/t the lower and upper plenum?
Will my crawford V5 upper intake plenum workt with this combo?
Old Apr 3, 2006 | 10:48 PM
Andy2434's Avatar
It does and can get a bit confusing. You would be well served by sending Tony a PM. He'll straighten everything out for you. Tony is a good person to work with.
Old Apr 3, 2006 | 11:13 PM
bosssho's Avatar
Roger that, thanks again!
Old Apr 3, 2006 | 11:29 PM
papagz's Avatar
the Mrev is for the 05+ 6MT's
however, new evidence shows that it can be used on the non-revup but requires some other things to be done
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
