Help! My G Is Acting Funny!
Old Apr 13, 2006 | 02:04 PM
gametox's Avatar
Angry Help! My G Is Acting Funny!
I have an 06 Coupe I bought about a month ago now.
I noticed starting from a couple days ago that...
when I turn the A/C on at 60 degrees its nice and cold.
at 61 degrees it turns SUPER HOT. and 61-90 degrees is all the same hot temp! Whats wrong with it????????
I took my car in to the dealership to get my aero kit and tints done and that has nothing to do with the A/C unit. So whats going on???????????????
AGH
Old Apr 13, 2006 | 02:08 PM
Down_Shift's Avatar
It's new.. you paid for the warranty when you bought the car... why not use it?
Old Apr 13, 2006 | 02:09 PM
TLS's Avatar
TLS
Usually if the outside temp is colder than the setting which you set at , it will blow hotter(compressor will not kick on). For some reason this is always the case for all the vehicle that I've own that has the auto climate controls.
Old Apr 15, 2006 | 09:18 AM
daveblank's Avatar
There is a temp sensor behind the bumper that could be unplugged. There is also a in cabin temp sensor under the driver side knee panle. I've seen them get left unplugged when work was done--Lojack--or things like that. I hope this will help.
Old Apr 15, 2006 | 09:10 PM
cscirpoli's Avatar
yeah same thing happened to me when i had my anti theft device installed, a GPS tracker basically on the car. They guy never plugged the sensor back in for the AC and the car would blow hot air until 62 degrees and then it would blow cold air at 61 degrees. funny.
Old Apr 16, 2006 | 12:06 AM
jgainnm's Avatar
^^^ same here ^^^. I had the stereo replaced and the tech forgot to connect the inside sensor. Took it right back and it was a 5 minute reconnect.
Old Apr 16, 2006 | 01:05 AM
SDG's Avatar
SDG
+1 Save the cries for help for the un-warrantied
Jeff469
Sep 25, 2015 09:28 AM
reaper76
Sep 20, 2015 11:59 AM
