Torque specs
Old Apr 24, 2006 | 11:48 AM
greenery's Avatar
Torque specs
I put on an intake, and I retorqued everything with no torque wrench. But I heard if you take it into service and everything is outta the torque spec they may deny you warranty. I plan to put everything back to stock before i take it in for some warranty.
Does anyone know the specific torque specs for the:
engine cover, intake tube clamp, maf sensor bolts, the spot with the pop-charger support and the other bolts needed to be adjusted for installing a z-tube/pop-charger ????
I also need the tq spec for the oil drain plug ??
Old Apr 24, 2006 | 01:22 PM
superchargedg's Avatar
who ever told you that should be hung out to dry.the techs dont check any torque readings while removing parts,also the majority of techs dont even use a torque whrench for anything.they all think they know better,btw ive worked in auto shops for 29 years.im a service mgr.
Old Apr 24, 2006 | 01:31 PM
jersey-G's Avatar
lol, taking the engine cover off voids the warrenty now?
Old Apr 24, 2006 | 03:18 PM
TheKnite's Avatar
My Infiniti service guy said the same thing, that the techs don't always use the torque wrench. I'm a little dissapointed. When I used to go to Costco with my previous car for wheel balancing or tires, they did use the wrench and I've watched them every time.
Old Apr 24, 2006 | 03:37 PM
thats cause they are in the tire bus,just about every tire company has a policy about wheel off,s as they are called,and they mandate torque wrenches,which still are hardly used.most use what is called a torque stick.i think there are 9 different ones and they limit torque applied to the wheels,depending on which one is used.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
