Motordyne Webpage Updated w/ MREV+?
Old Apr 26, 2006 | 05:17 PM
jonnylaw's Avatar
I just checked the Motordyne website and it looks as if There is now only the MREV++ (benefits all G35's) and the spacers (there used to be a sepatate MREV system and additional MREV+). Can anyone verify?
http://www.motordyneengineering.com/G35.asp
Old Apr 26, 2006 | 05:50 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No, I don't think so...
Old Apr 26, 2006 | 05:52 PM
jonnylaw's Avatar
Then how come, there is no more MREV package for revup engines and the MREV+ plus says it benefits all G35's?
Old Apr 26, 2006 | 07:01 PM
99atlantic's Avatar
Maybe that is updated? It says Mrev Plus + so I get that's mrev ++ ?
Old Apr 26, 2006 | 07:14 PM
Fox233's Avatar
It says MREV PLUS + Lower collector.....as in MREV PLUS and the Lower Collector in one package.
Old Apr 26, 2006 | 07:15 PM
99atlantic's Avatar
or mrev++ lower collector?
Old Apr 26, 2006 | 07:51 PM
Andy2434's Avatar
It appears that Tony has simply reorganized everything. It seems that the original MREV package is no longer available. Now, the MREV + is the only lower collector option.
Old Apr 26, 2006 | 08:09 PM
jonnylaw's Avatar
Andy, so basically by purchasing the mrev+ as it is currently on the site along w/ the 5/16 spacer iso thermal plenum, this would be essentially what you have on your vehicle?
Old Apr 26, 2006 | 08:28 PM
Andy2434's Avatar
Yes, that would be correct. The only thing you would have to decide upon is which Thermal package. There are 2 . . . The Copper ISO Thermal Plenum Spacer Kit or the ISO Thermal Plenum Spacer Kit. They each do essentially the same thing. The difference is how the heat from the coolant is regulated at the Throttle Body.
The Copper ISO kit utilizes a copper heating plate, which once installed never needs any further attention. The regular ISO kit utilizes a coolant control valve, which is turned on when the outside air temperatures are below some 55'F and turned off when the air temp is above the said.
Edit: The copper heating plate is installed between the Throttle Body and the upper collector. The Coolant Control Valve is installed in an existing coolant line, located under the intake tube.
Old Apr 26, 2006 | 08:52 PM
jonnylaw's Avatar
Ok, thanks Andy--I ordered the copper
Old Apr 26, 2006 | 09:04 PM
Andy2434's Avatar
You're quite welcome. Enjoy your new mod. I know you will.
Old Apr 26, 2006 | 09:26 PM
dennis_said's Avatar
Wow so now I can get MREV for my 2003 AT? o.O?
Old Apr 26, 2006 | 10:05 PM
Andy2434's Avatar
According to Tony's latest dyno data . . . Yes!
Old Apr 26, 2006 | 10:06 PM
WQHOAOA!!!! <--- that typo suggests how excited I am =D
Hexxum001
Forced Induction
363
Nov 8, 2015 11:58 PM
Joaquin03
Oct 23, 2012 01:36 PM
Hydrazine
Intake & Exhaust
360
Dec 1, 2009 11:52 PM
Glex25
Intake & Exhaust
41
Mar 29, 2009 01:25 AM
ISMSOLUTIONS
Forced Induction
27
Dec 19, 2006 07:26 PM
