AC is going CRAZY!
Old Apr 28, 2006 | 05:55 AM
aleok's Avatar
AC is going CRAZY!
i discovered tonight was that my AC is ****ing up. at 60 degrees is cold air, but at 61+ is warm/hot!!! WTF! i know someone else had this problem on this forum. i know warrenty should cover it, but i'm worried about my mods. i have, modified stock g-tube, k&n drop in, 1/2 MD spacer, fogs in lower grill, sounds, crawford HF catsaftermarket shock sensor. i just installed the sensor this week. if someone could help me find the old thrend or info on what i should do. should i change my car back to stock? i assume the infiniti dealer here isn't very mod-friendly being the only one. please help!!
Old Apr 28, 2006 | 07:24 AM
Eddie23's Avatar
Did you disassembly your dash recently? If so the cause could be that the hose or the plug of the inside temperature sensor weren't plugged back in. I had this case. The sensor is on the right side of the mid-console, right under the plastic.
Old Apr 28, 2006 | 06:03 PM
aleok's Avatar
yes, i did disassemble my dash,( under the steering wheel) if ur talking about the mid-console as in under the wheel then i think i know what ur talkin about. i'll check on that. thanks
Video Share
Jan 31, 2017 04:00 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
reaper76
Sep 20, 2015 11:59 AM
carsmacked71
Sep 18, 2015 04:13 AM
NJ6MT
Sep 10, 2015 08:40 AM
