Turn Signal stops working after a few actuations.
Old May 3, 2006 | 01:25 PM
myTBG35's Avatar
This may belong in the lighting section but I thought someone here might be able to help (technical aspect)...
I recently had a high intensity LED setup installed in the turn signal assembly
on my 04 G35 Coupe.
Problem: The turn signal will stop signaling after 3-5 actuations when the engine is running. If I reactuate the turn signal soon afterwards it will stop working after just the 1st actuation. This is the same on both sides.
When the engine is completely off the turn signals work and will not stop even after 100 actuations.
I understand that the running voltage when the car is running is higher which may cause certain modules (light control module?) to detect a beyond spec reading.
The LED setup has a 2.1 amp draw.
Does anyone know a way to circumvent this so the turn signal will work all the time? Thanks for the help!
Old May 3, 2006 | 08:26 PM
TopTech's Avatar
WTF is "a high intensity LED setup installed in the turn signal assembly "?
Old May 3, 2006 | 09:26 PM
Curt G's Avatar
on my 04 G35 Coupe.
2.1 amps for turn signals?
It does sound like a voltage issue IMO.
So, when do we get to see some pics or a video of this setup?
Curt
Old May 4, 2006 | 09:53 AM
myTBG35's Avatar
I have this retrofitted in amber:
http://www.laminaceramics.com/products/bl2000.aspx
LED's are notoriously dim, this solves that problem..... but creates another yippie!
I'll post pics and videos when it's all working properly.
Does anyone know where the turn signal relay would be on our coupes?
arora_g35
Apr 16, 2026 02:52 PM
tal1412
Nov 28, 2022 09:25 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
justgotg35
Jul 19, 2015 12:33 PM
