WOW engine turn off at high speeds again
Old May 5, 2006 | 10:25 AM
ONEmike's Avatar
Ok this is the second time this has happened to me. im driving home and decided bah nice day not many cars why not punch it a bit. i im in 5th gear going about 150kmph and then slow down because there are cars in front. i leave the car engaged in 5th and start breaking. then i notice all the lights on my dash and think damm what happened. so i turn on the off ramp and my power steering is gone, then i realize my damm engine shut off on my again!
i understand that a few other people have had this problem, is there a fix yet? or should i bring it in to the dealer for them to pick apart. i have a stillen intake and thats about it, could it be that there is too much air or too little air going to the engine? whats your expierences with this problem
Old May 5, 2006 | 10:52 AM
GT-Ron's Avatar
I haven't heard of the Stillen intake causing this type of issue, so my suspicion would be with the throttle-body or MAF.
Old May 5, 2006 | 12:17 PM
djbab00's Avatar
my engine light came on recently and the dealer found a faulty maf. the explination given was the motor to open the maf died. so you might want to check that out. otherwise good luck
Old May 5, 2006 | 01:10 PM
luongdmd's Avatar
take it in...... or find out a lemon law.... i don't think this is normal....
Old May 5, 2006 | 01:30 PM
WYSIWYG's Avatar
Is it possible for the engine to completely shut off when you are still in gear and rolling at ~60-100 mph? And so smoothly that you wouldn't notice that your engine is no longer running?
How did you get out of the situation. Just coasted until you could stop in a safe place and just restart the engine? The only cases I've experienced w/ aftermarket filter related stalls is only during idle or out of gear after acceleration. The suggestions to look at the MAF and throttle body are good places to start. However, i would just swap out the stillen box back to stock and take it in to dealer. You don't want them to blame a faulty MAF or blow it off by saying it is your intake mod. Your going to have to be able to reproduce the stall during a ride-along if they can't find anything or if they can't see anything in the error log.
Old May 5, 2006 | 01:33 PM
mephistomyhero's Avatar
There's those words again.."lemon law". Sheesh, it's like once something happens that is unusual, people are so inclined to use the lemon law.
Anyways, do a search, from what I've seen, whenever something like this, it is either the MAF or the CAI. I've seen more from the CAI then from the MAF, but I have seen both. It is always when the car is in gear and slowing down or turning a corner. Like everyone else said, take it to the dealer. If they can't find anything wrong with it, maybe it is the CAI. Did this happen before when you had the CAI?
Old May 5, 2006 | 01:48 PM
99atlantic's Avatar
10-1 it's the stillen intake that's causing problems. a lot of them like stillen and popcharger and nismo are notorious for kshutting off yoru engine
Old May 5, 2006 | 02:22 PM
wnt1bd's Avatar
I've never heard of a Nismo doing this......I have heard a few Stillen's though. I've got Nismo, and trust me I do alot more high speed driving then most and I don't have any issues.
Old May 5, 2006 | 02:28 PM
RedG's Avatar
<--12 More Years
This happened to me once too. I couldn't figured out what it was, but It has not happen again. I have an Injen CAI too.
Old May 5, 2006 | 02:38 PM
overdrve's Avatar
Best bet seems like the MAF. However, all the accounts of MAF failures I heard were that the car would go into a "safe mode" and just prevent reving past 3k rpms. Another possiblility could be the crank position sensor. I had an Altima before my G which has the same VQ engine and there was a recall on the sensor causing complete shutdown of the car even at highway speeds. I would highly doubt our cars have this faulty sensor, but it could be a possibility based on your experiences.
Old May 5, 2006 | 03:58 PM
wnt1bd's Avatar
I read somewhere a while ago, that when you use new intake systems sometimes they are over oiled, and the oil builds up on the MAf sensor and does that. Like I said it was a while ago I read this so take that for what it's worth.
Terry_G35
May 9, 2020 01:39 AM
derres
Aug 28, 2015 03:27 PM
Terry_G35
Aug 4, 2015 02:38 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
