Clicking noise from front windows
Old May 20, 2006 | 12:56 AM
ymisotall's Avatar
I was wondering if there is a fix(TSB) for the clicking noise coming from the front windows (when roll all the way up) for the sedan? I know there was a fix for the rear, which I had them fixed, but the front ones are starting to irritate me. Thanks all.
Old May 20, 2006 | 11:44 AM
ABQ_G35's Avatar
I recently had a similar noise, does it stop when you take the window down slightly? It was just my passenger door. They removed the door panel and "insulated" some stuff in there, it's gone now, I tried before to get it fixed, finally this time, I talked to the tech, not the writer, that did it!
Old May 21, 2006 | 07:34 PM
ymisotall's Avatar
There isn't a clicking noise when the windows are slightly down. It was make the noise when it's fully rolled up. is there a fix for this or is this something Infiniti will fix for free?
Old May 21, 2006 | 09:03 PM
JimG35's Avatar
I get more of a 'clank' when lowering the window.
With the window half down, I can grab it and pull it up & down almost an inch.
Is this nornal/ok?
Old May 21, 2006 | 10:42 PM
ABQ_G35's Avatar
It's in the door panel, guess when the window is up it changes the position slightly, they insulated the wires, cables and some other things inside, and the noise has stopped, I say as I knock on wood...............I guess it depends on the year of your car, and most likely, your dealer.
Old May 22, 2006 | 10:15 AM
SixFive's Avatar
THe TSB actually addresses an issue with the actuator. When replaced or greased (along with a nice streak on the glass), the noise will stop. THis is different that noises cause by renegade connectors and wiring.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
will091195
Jul 27, 2015 09:19 PM
rping
Jul 26, 2015 09:53 PM
papo020
Jul 17, 2015 10:30 PM
