need wheel/tire experts opinion
Old May 21, 2006 | 11:23 PM
TheTrance's Avatar
ok so after a few weeks of research ive decided to go with the following setup. please let me know if there are any problems (rubbing, VDC issues, etc) as i'm planning to buy these tomorow morning
18x8.5 +38 with 245/45/18 tires FRONT
18x9.5 +45 with 275/35/18 tires REAR
car is a 03 sedan btw
Thanks
Old May 21, 2006 | 11:41 PM
NorthSideRacing's Avatar
man dont get 18's.. get 19's atleast. go with some 19x8.5 front and 19x9.5 rear
Old May 21, 2006 | 11:43 PM
vodkarocket's Avatar
Modded Member
Thanks
The wheels specs are perfect. In regards to tires, I would either go 245/45/18F & 275/40/18R or 245/40/18F & 275/35/18R.
Old May 21, 2006 | 11:48 PM
TheTrance's Avatar
I really wanted to reduce the fender gap in the front thats why i decided to get 245/45/18F..
For the rear, i read somewhere that 275/40/18 would rub with 18x9.5 +45
Old May 22, 2006 | 02:27 AM
GLuXuRy's Avatar
Dont fill in fender gap with more rubber... i would get a bigger rim... 18's are ok but 19's are better
Old May 22, 2006 | 05:18 AM
codeflux's Avatar
i would go +40 in the back, if you are considering stoptech's 14" BBK in the back. i have it (14" stoptech BBK front & rear) and in the back the clearance between the caliper and the wheel is about 1.5mm - this is with +43 offset in the back. if you go a little higher, it won't fit.
now, that's the only consideration - but i'd go with equal offset front and rear on 8.5-wide and 9.5-wide rims. +43 would be perfect, +40 and +45 would also work.
+50 in the front *will* rub on the shocks.
Old May 22, 2006 | 10:59 AM
TheTrance's Avatar
so no VDC issues with the setup i mentioned?
Old May 23, 2006 | 09:41 PM
skeleton_cru's Avatar
Sedan
Thanks
Offsets are good, but I would go with 245/40f and 275/40r. Closest to stock tire height and minimum speedo error.
Old May 24, 2006 | 11:20 AM
dyenboy's Avatar
Registered
wa wheels are you plannin to get..jus curious?
Old May 24, 2006 | 01:47 PM
Endless G's Avatar
I ordered my rims as well and am looking to do
either 245/40/18 and 275/35/18 2.58% difference
235/40/18 265/35/18 3.08 difference
Which one should i go with, and will VDC be an issue here??!
Old May 28, 2006 | 02:17 AM
Sedan
Here is the tire size calculator I use.
http://gs.tolan-hoechst.com/tirecalc.htm
There are some others out there as well.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
