Just got my alignment done on my G lowered on 350Z suspension. Review numbers
Old May 23, 2006 | 06:17 PM
vrsc's Avatar
My alignment update:
Here's the factory specs for the 04-05 sedans with sport suspension:
Front:
Camber: -0.8/0.7
Caster: 7.0/8.5
Toe: 0.00/0.08
Rear:
Camber: -1.1/-0.1
Toe: 0.00/0.22
Specs after installing 05 350Z full suspension and before the alignment:
Front:
Left: Right:
-0.8 Camber -1.5
8.3 Caster 9.3
-0.01 Toe 0.00
Rear:
Left: Right:
-1.5 Camber -1.3
0.12 Toe 0.04
Specs after alignment:
Front:
Left: Right:
-0.9 Camber -1.4
8.3 Caster 9.3
0.05 Toe 0.05
Rear:
Left: Right:
-1.0 Camber -1.0
0.07 Toe 0.10
How are these specs? They mentioned that I should purchase a Camber kit, but I just said no
Old May 24, 2006 | 09:00 PM
vrsc's Avatar
no one has any comments?
Old May 24, 2006 | 09:44 PM
Machine Head's Avatar
camber looks way off, plan on premature tire wear without a camber kit
Old May 25, 2006 | 01:06 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The numbers look good vrsc, i already posted in the other thread about them lookin good that's why i didnt post in this one, but anyways, they're good.
-GP-
Old May 25, 2006 | 02:16 AM
absolutg's Avatar
workin...
i have comments . they are similar to my numbers, but one thing i noticed is that your front camber differential is more than twice mine. the differential being the difference between left and right. usually it's ok if your camber is out of spec as long as the differential is close to zero while the toe is within spec. same thing for front caster differential. one thing for me tho, i just swapped my springs...
if you like, PM me and i can send you my #'s
Old May 25, 2006 | 02:36 AM
godmans's Avatar
your aligned numbers look okay to me, however, just like what absoluteg has said, you might want to lower the front camber differential to maybe < 0.3
Old May 25, 2006 | 02:38 AM
front camber is non-adjustable unless you purchase and install a camber kit, otherwise the numbers are not toooo far out of spec. for being lowered.
-GP-
Old May 25, 2006 | 10:02 PM
vrsc's Avatar
Thanks guys for the thoughts. I will watch my tire wear and see if any problems arise
Old May 25, 2006 | 10:07 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
Who did your alignment and are they open on saturdays?
Old May 25, 2006 | 10:37 PM
Klubbheads's Avatar
Looks good except the front left and right camber difference.
Old May 25, 2006 | 10:41 PM
ttrank's Avatar
Grocery getter
+1
The -1.0 to -1.5 is strange. I have about -1.5 on both with H&R springs.
Old May 25, 2006 | 11:40 PM
Cracker Red's Avatar
The camber is a bit off from R/L, but what most do not realize, is it's toe that will wear tires out FAST, not camber....
Old May 25, 2006 | 11:47 PM
sorry cracker, but are you on crack?!?! Camber is what wears tires faster than anything, depending whether it is positive or negative, excessive camber will prematurely wear the inside or outside of the tire. Toe is a factor in tire wear but toe settings attribute to the steering being straight.
-GP-
Old May 26, 2006 | 07:35 AM
vrsc's Avatar
Tires Way of America (SR 50 and Semoran Blvd) Close to Waterford Lakes
321-235-5588
Old May 26, 2006 | 07:42 AM
vrsc's Avatar
I believe this difference is attributed to the car from the factory. I have taken it to the dealer 3 times in reference to it pulling to the right. The problem was that I but wheels and tires on the car pretty early into the game of the new purchase and dealer placed blame on the aftermarket stuff. The car is still pulling to the right, just as it has since new??? I have called the dealer numerous times to get copies of the alignement specs but somehow they can't find them?? So I'll just have to watch for excessive tire wear.
Thanks for the comments
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
NohoG35revup
Aug 22, 2015 12:13 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
beevanhuynh
Jul 23, 2015 01:37 AM
