Clicking noise from rear of car
Old Jun 1, 2006 | 10:18 AM
ITRS2K's Avatar
I have a 2005 G35 6MT with 8700 km on it. Very recently with the warmer weather (window down), I notice a clicking noise coming from the rear of the car. It is reproducable from standstill to moving. Once it reaches higher speeds (40km/hr) it is not noticable. It varies from one click to 2-3 clicks in succession, seems to increase with harder accelerations.
At first, I thought it was related to the clutch. I thought everytime I depressed the clutch it would make one click but I was wrong....I can leave the car engaged in second gear (< 10km/hr).....once I step on the gas, the cars weigh shifts to the rear and I get 1 or more clicking noise. The harder I accelerate, the more the click. Once it gets going, there is no more noise.
I speculate it is the rear suspension (spring on compression? Bump stop?). The dealership will have a look next week. Will post the results.
Any help would be good.
Old Jun 1, 2006 | 11:33 AM
da mayor's Avatar
maybe it's the sound from the limited slip rear differential? does it sound when you floor it and shift hard?
Old Jun 1, 2006 | 11:50 AM
shodog's Avatar
it's your axles. This is a common problem and I got mine replaced under warranty.
Old Jun 1, 2006 | 12:06 PM
kajoob's Avatar
Does this occur on the 2004's as well? I have an '04 and I hear a clicking noise as well, but I was told it was clutch chatter and that it was normal
Old Jun 1, 2006 | 01:53 PM
jetblackg35's Avatar
Ther is a bulletin out for your car take it to the delearship you need part #s
Bolts(driveshaft side flange) 39606-22P00 Quanity 6 per side
Nuts(driveshaft side flange) 39607-03p00 " " " "
Washers(driveshaft side flange) 08915-1401A " " " "
Cotter Pin 40073-0L700 Quanity 2
Old Jun 1, 2006 | 01:54 PM
This is a common thing by the way!!!!!!!!!!
Bryan
Inskip Infiniti Parts Manager
Old Jun 1, 2006 | 09:22 PM
shaigh's Avatar
I had a similar clicking noise whenever I started to move the car (forward or reverse)....took it to the dealer, who performed a coupe TSB to tighten some rear axle bolts. The TSB was listed for 03 and maybe 04 coupes, but not 05's, and not sedans. Seems to have fixed the problem, though. I have not heard the clicks since then.
Old Jun 2, 2006 | 01:21 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
+1. Tighten the axle spindles.
Old Jun 2, 2006 | 01:20 PM
nr2134's Avatar
I have the same thing, but I noticed it after I lowered the car and changed rotors and pads. Last night I took everything apart like 3 times because I couldnt figure out where it was coming from. Its freakin loud and annoying tho.
Old Jun 6, 2006 | 11:48 PM
ITRS2K's Avatar
Just an update....took the car to the dealership today. They quickly identified it as being a TSB. The mechanic said they need to apply lubricate to the axle and spindle to get rid of the noise. It would take approximately 2 hours. Since it is not super serious, I will get it fixed at the next oil change.
Will let everyone know if this does it...
thanks
Old Jun 24, 2006 | 10:41 PM
kidtronix's Avatar
Optional
BTW, the TSB DOES apply to 2005's as well as '03 and '04 cars. (http://www.infinitihelp.com/Ownershi.../ITB05-002.htm) I have 9100 miles FYI (mostly easy cruising)...so apparently it doesnt take long for this to occur.
LOL I just did a search for the axle clicking threads because mine started the click today. I needed to confirm that it was the same as everyone elses claim...and I'm hearing it EXACTLY like ITRS2K. Thank God for this website or I wouldn't have been able to anticipate this axle issue long before it occurred Getting axle #1 fixed when she goes in for the next oil change!
Is this what I get for running it hard lately? I'm just trying to hear my Z-tube (which incidentally doesnt really sound much different than the stock intake). I was just trying to keep carbon deposits from building up on my valve seats!
Old Jun 26, 2006 | 09:40 AM
esfoad's Avatar
Does this "clicking" also occur on AT X's? I hear a clicking when I shift into reverse Seems like I can reporduce the sound at will. I will also mention it to the dealer at the next service (33750 mi)
Old Jun 26, 2006 | 10:10 AM
GFN-G35's Avatar
i had the same thing and it wasnt any of those.
it turns out the brake pads have a metal plate infront of them and whenever you move they make a clicking noise against the brake pad pins.
Old Jun 26, 2006 | 01:10 PM
Garyv01's Avatar
had the same problem on my X...dealer said it's a common problem and they fixed it for free...has something to do with te rear suspension...that $hit got on my nerves
Old Jun 27, 2006 | 05:49 PM
jayelleseven's Avatar
From: socal--not leavin this place, jus takin over it one venture at a time.
do u know if u can take it to a dealer close to you or it has to be the one where u copped the G???
how serious is this problem?
