eibach springs for 03.5 sedan
Old Dec 1, 2006 | 05:29 AM
rijen1013's Avatar
only in the rear but my shop in southcity has a camber kit that their selling for cheap.
Old Dec 1, 2006 | 10:00 AM
ORANGEBSRT's Avatar
I think that is the perfect drop.
Old Dec 1, 2006 | 11:03 AM
erdog's Avatar
What camber kit is your shop selling and can they mount and do an alignment?
Old Dec 1, 2006 | 11:29 AM
OCG35's Avatar
The camber is out of spec?... Everything I have read says the Eibach pro keep everything within spec (just barley though)... one reason I was considering this rout was because of no additional alignment parts necessary. Now I might be re-considering.
Old Dec 1, 2006 | 12:51 PM
rijen1013's Avatar
it does keep it in spec (just barely though) i put the camber kit on cause it was only like $50-60 bucks but before that i had no problems.
Old Dec 1, 2006 | 02:02 PM
OCG35's Avatar
Right on, thanks.
BTW (anyone), how long should I wait for an alignment? I have an appointment (for alignment) sched next Thur and I won’t be able to have springs installed until Mon which gives only 3-4 days for the springs to settle... I've been told the springs won’t fully settle for 500-1000 miles. Would it be a waste to align within 3-4 days of install?
Old Dec 1, 2006 | 02:10 PM
perry05G35's Avatar
I had eibach prokits you will NEED to monitor your tire wear if you are not going to get the camber kit. The prokits cased un even wear in my tires down to the steel belting in the 7K mile interval after my last tire rotation and balance. At the time the tires I had (Toyos) had 5K miles on them. The springs were great and handle well. Take your car to another shop and get them to check your camber/toe specs to make sure it's not going to cause an expensive tire replacement down the line.
Old Dec 1, 2006 | 03:08 PM
ORANGEBSRT's Avatar
So pretty much any brand of spring u put on the car, u have to have a camber kit? Is that what u r saying.
Old Dec 1, 2006 | 04:16 PM
rijen1013's Avatar
i would wait on the aligment until after the 500 mile mark.
Originally Posted by OCG35
Right on, thanks.
Old Dec 1, 2006 | 04:21 PM
rijen1013's Avatar
it was a stc camber kit they can do the install but they dont have the machine got the aligment. caos wise to install around 65-75 dollars.
Old Dec 1, 2006 | 06:16 PM
OCG35's Avatar
Did you get an alignment after installing the Eibach springs?... I plan to get an alignment within 4 days of install then again after a few thousand miles (or a few months)... If it can be initially aligned without camber kit I should be good to go - right?...
BTW, I had thought about waiting 500-1000 miles after spring install for alignment but I recently got new tires too - so an alignment now is needed anyway... also I spoke to Darin at West End (where I'm getting my alignment done) and he suggested doing it now then again in about 8-12 months. Makes sense and since he is reported to be about the best alignment tech around I trust what he's telling me...
Old Dec 2, 2006 | 03:09 PM
perry05G35's Avatar
My alignment was done with the install of the springs. When I had the eibachs removed I was told my alignment was not out of spec. However the proof was right in front of me the wear of the tires was a result of camber/toe. I purchased new tires and brought the SPC rear camber kit and was going to get the front camber kit when it came out but it turned out to not be cost effective. The rear camber kit was 200-235 and the front was 400-500 range. That is more than I actually paid for springs and getting the car lowered. I sold the rear camber kit and put my factory springs back on and I will wait and see the long term effects of 350z/G35 coupe springs on our sedans.
My point is to be aware that there is the possiblity that you can wear your tires with out a camber kit it could have been just my experience but I wouldn't feel like a g35driver if I didn't share with you what happened with me.
Old Dec 2, 2006 | 03:13 PM
perry05G35's Avatar
No what I am saying is monitor your camber/toe and tire wear to make sure everything is still in spec and no weird tire wear. If your camber/toe is too far out of spec and can't be corrected purchase the camber kits to bring it back in spec regardless of the suspension setup you have.
Old Dec 2, 2006 | 04:41 PM
OCG35's Avatar
Thanks for the heads up... I hope mine is in spec... we'll see
reavensf
Sep 17, 2015 11:30 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
