20'x 8.5 fit on the sedan with out droppin or fender mods???
Old Jun 20, 2006 | 09:36 PM
gfolo19's Avatar
Deciding to by rims will the 20x8.5 fit or should i get the 19's?
Old Jun 20, 2006 | 09:40 PM
Chico's Avatar
yes it will with +35 to +40 offset is ideal with 245/35/20 tire.
Old Jun 20, 2006 | 10:46 PM
ttrank's Avatar
Grocery getter
Yeah, what Chico said....
Old Jun 20, 2006 | 11:41 PM
gfolo19's Avatar
follow up will it look weird with out being dropped? and is it possible for 20x10 in the back?
Old Jun 21, 2006 | 12:12 AM
ttrank's Avatar
Grocery getter
Yes and yes.
I don't like the look of the sedan with aftermarket wheels and stock height.
I have 8.5's front and 10's in the rear with H&R springs (1.0F, 1.2R).
Old Jun 21, 2006 | 02:20 AM
gfolo19's Avatar
ok so if i got 20's i have to get it dropped for it to look good? but will 19's with the right tires allow me to keep stock height?? and if i got 19x10 or 20x10 in the back will i need to modify anything for them to fit? sorry theres just alot of rim/tire options and im having trouble deciding...im lookin for the best combo/least maintence...thanks
Old Jun 21, 2006 | 02:26 AM
az1anbeethoven's Avatar
i have 20x8.5 with a +35mm offset and 245/35/20 tires and it looks great! it will sit flush to the fender...it still looks nice without being dropped...if you are not dropping your car, i would get 245/40/19 tires if you plan on going with 19x8.5 wheels...
Old Jun 21, 2006 | 02:27 AM
codeflux's Avatar
listen to Chico - he KNOWS his tires.
Old Jun 21, 2006 | 02:28 AM
Klubbheads's Avatar
sedan is too high for any kind of rims even with stock 17s. So if u change rims plz drop it.
Old Jun 21, 2006 | 12:02 PM
da mayor's Avatar
definitely lower the car w/ 20 x8.5
Old Jun 21, 2006 | 01:45 PM
ttrank's Avatar
Grocery getter
I think it should be lowered either way. If you don't lower it make sure and get tires with a decent size sidewall.
If you don't lower it, you might be able to get away with 10's in the rear and no rolling. If you lower it you will need to roll your fenders.
Why don't you want to lower it? At least with 350Z springs, they don't take it down too much; just enough to make it look clean.
Old Jun 21, 2006 | 10:12 PM
gfolo19's Avatar
Im out in NY tons of pot holes and crappy roads from the snow in the winter, I used to have a sentra ser spec V with z rated tire on 18's on my car and got a flat tire once a month...i just got off the phone with a shop from cali, ordered 19"x8.5 black mesh machined lip...with 245/40/19 tires, i need a stronger sidewall/stronger tire to deal with the roads out here dont got the luxury of the cali weather plus if i lower it ill bottom out even more then i do already thanks for everyone's advice pics will be up as soon as i get the rims!
Old Jun 21, 2006 | 10:49 PM
ttrank's Avatar
Grocery getter
Wow, if things are that bad maybe you should keep it stock height and get a 45+ series.
Either way, good luck and post some pics when they are on.
Old Jun 22, 2006 | 02:29 PM
gfolo19's Avatar
im tryin to find a solid pair of 245/40/19 you think 45's would be better, i dont want to much rubber and drawf the rims...i want something that compliments opinions welcome
Old Jun 22, 2006 | 04:10 PM
da mayor's Avatar
245/40/19's falken makes which neal376 has or nitto makes a tire for $200 a piece
