Help Please
Old Jun 21, 2006 | 07:26 PM
LILShiraz's Avatar
Help Please
I recently purchased a used 2003 G35 Sedan, and after a couple weeks with it i noticed that sometimes when i start the car, the radio, air condition, and all the lights in the das board (speedometer) do not turn on. has anyone had a problem with this, and does anyone know what is wrong with it.
also i noticed that the mirror, that is under the sun shade is broken, i never use the mirror, however i would like it a lot more if it wasnt broken, where can i get a new one from? thanks a lot
Old Jun 21, 2006 | 07:51 PM
G SEDAN's Avatar
right next to the trunk opener and the VDC switch there is a little wheel, it is the **** to adjust the brightness of the dash lights and make sure it is adjusted to the brightest position. I had a problem when i first bought the car that when my headlight was on the dash light doesnt come on. after messing with it. I figured that the dash lights are always on but when i turn on the headlights the dash lights are determined by the adjustable ****. I hope this helps.
Old Jun 22, 2006 | 10:58 AM
LILShiraz's Avatar
thanks, but i already messed around with that ****, but it has nothing to do with that, i think its like a loose wire or something, becasue nothing turns on, the radio, AC, and dash lights
