Finally lowered my "X"
Old Jul 10, 2006 | 11:48 PM
mikeee2's Avatar
Originally Posted by aam6906
no rubbing but bouncy as hell with people in the back, u have that problem?
Seems like all of the X owners that dropped gets the bounce in the back. I wonder if the rwd with lowered springs and oem shocks have the same issue.
The other thing is, if X owners replaced the rear shocks with z shocks, will that fix the problem.
Old Jul 10, 2006 | 11:51 PM
Neal376's Avatar
ask da mayor - he just dropped his 06 6speed on aftermaret springs
lately he has been beating off to the handling of his car, so i guess he is not getting the bouncing issue
bahhahha. i am not joking
Old Jul 11, 2006 | 12:55 AM
aam6906's Avatar
Originally Posted by KrazyEd
I have only had 1 person in the back so far and yes it does get a little more bouncy. I am going to have 2 people in the back this weekend so I will let you know how that goes.
I should be going to get an alignment in a couple of days. Although I do think that the negative camber is helping me from not hitting the fender. It looks as though iI will rub against my fender if I get my negative camber fixed.
yeah, you most likly will have a little negative camber in the rear but itll help cornering anyways.......my car has a little negative camber, but nothing bad........hasnt ever rubbed and i got my springs on last summer........
Old Jul 11, 2006 | 12:57 AM
aam6906's Avatar
i was gonna get tokicos for the rear but decided not to when i found out you have to get the whole set front and rear so it wasnt worth it........
Old Jul 11, 2006 | 01:06 AM
mikeee2's Avatar
What are your camber specs in the rear? So the oem shocks are still holding up?
Old Jul 15, 2006 | 10:56 AM
KrazyEd's Avatar
Dropped off the car to get an alignment. I will post up the alignment results when they are done.
Old Jul 15, 2006 | 12:24 PM
Gsedan35's Avatar
Flicking the steering wheel and spiking the spring rates sky high as you quickly run out of shock travel, does not make great handling, it makes the illusion of it. He has a 2.2" drop on shocks that are 3/4" TALLER then oem Z shocks. I ran a 2" drop on Tokico D-spec springs, and even with Koni's that are the same lengh as oem Z shocks, I was consistently hitting the bump stops. And I also have special progressive soft Koni bump stops that are shoter then the oem units. You have to actually have suspension travel to get good handling, going with that much drop on springs won't deliver that.
Old Jul 15, 2006 | 12:37 PM
Gsedan35's Avatar
I would think that the issue would be worse amoung those that went with revised oem Z springs since they are 427lbs vs 342lbs in rate.
It's never been a issue that can recall seeing in reviews. I didn't have bounce with oem Z springs revised or unrevised. But I did p/u on rear shock control issues where I do not recommend revised Z springs on any oem sedan shock.
Well, it will fix the problem if you use revised oem rear shocks. However, it will give you a far worse problem. Too much rear dampning stiffen's up the rear to the point that the car is not enjoyable to push anywhere past 7/10th. I hated the setup so much I quickly pulled the rear shocks, very quickly.
I could see someone putting rear Tokico D-specs on since they are double adjustable and not setting them past half way.
Old Jul 15, 2006 | 12:53 PM
KrazyEd's Avatar
ok...just got it back. Here are the specs. Let me know what you guys think.
Front Left(Before): Front Left(After):
Camber: -1.5----------------Camber: -1.6
Caster: 7.6------------------Caster: 7.6
Toe: -.21-------------------Toe: .06
SAI: 6.0---------------------SAI: 6.1
Included Angle: 4.5--------- Included Angle: 4.5
Front Right(Before): Front Right(After):
Camber: -1.5---------------Camber: -1.4
Caster: 6.9-----------------Caster: 6.9
Toe: .02--------------------Toe: .07
SAI: 6.1--------------------SAI: 6.0
Included Angle: 4.6---------Included Angle: 4.6
Front(Before): Front(After):
Cross Camber: 0.0-------------Cross Camber: -.02
Cross Caster: .6 --------------Cross Caster: .6
Cros SAI: -.1------------------Cros SAI: 0.0
Total Toe: -.20 ---------------Total Toe: .13
Rear Left(Before): Rear Left(After):
Camber: -2.6 ---------------Camber: -2.2
Toe: .28 --------------------Toe: .15
Rear Right(Before): Rear Right(After):
Camber: -2.2---------------Camber: -1.5
Toe: .05 -------------------Toe: .12
Rear(Before): Rear(After):
Cross Camber: -.3-----------Cross Camber: -.6
Total Toe: .32---------------Total Toe: .28
Thrust Angle: .11------------Thrust Angle: .02
Old Jul 15, 2006 | 01:06 PM
mikeee2's Avatar
Your rear specs looks better than mines thats for sure. Wonder why mines are so off -2.9/-2.5. I will be swapping the rear out with coupe springs soon and then I'll post my alignment specs afterward. Where did you go for your alignment?
Old Jul 15, 2006 | 02:33 PM
KrazyEd's Avatar
I got my alignment done at Tire barn in North Brunswick NJ.
Old Jul 15, 2006 | 06:03 PM
KrazyEd's Avatar
I dont really know to much but are these alignment results decent?
Old Jul 16, 2006 | 11:06 PM
KrazyEd's Avatar
Old Jul 16, 2006 | 11:12 PM
mikeee2's Avatar
Today I removed my rear tire and I start to see noticeable wear on the inner tire (my camber is worst than yours of course). If you had read my earlier posts, I was going to install coupe rear springs today but had issues. I have pretty much decided to go back to stock on my X. There's no aftermarket shocks for it and the oem just can't handle it (at least my opinion). If I do go back to stock at least I've been there, done that on the drop.
Old Aug 15, 2006 | 10:01 PM
  #30
KrazyEd's Avatar
Guys,
I am selling my rims for $1100 plus shipping. Please let me know if you are interested. They have about 4500 miles on them. Still in good condition
