Finally lowered my "X"
Originally Posted by Gsedan35
Flicking the steering wheel and spiking the spring rates sky high as you quickly run out of shock travel, does not make great handling, it makes the illusion of it. He has a 2.2" drop on shocks that are 3/4" TALLER then oem Z shocks. I ran a 2" drop on Tokico D-spec springs, and even with Koni's that are the same lengh as oem Z shocks, I was consistently hitting the bump stops. And I also have special progressive soft Koni bump stops that are shoter then the oem units. You have to actually have suspension travel to get good handling, going with that much drop on springs won't deliver that.
explaine "illusion"
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
