3m
Old Jul 21, 2006 | 03:56 PM
Choonz's Avatar
3m
hey guys,
i'm about to sell my ride and i would like to know if anyone knows how to remove 3M tape ???
Old Jul 21, 2006 | 04:00 PM
Nickk6's Avatar
if you are talking about the double sided foam tape, good luck. Gonna need a lot of bug and tar remover, some wax, some terry towels and a blow dryer. The older it is, the harder it is to get off.
Old Jul 21, 2006 | 04:03 PM
Texasscout's Avatar
Lot's of "GooGone"
twitch's Avatar
goof off does ok removing stuff like that. Usually you have to let it sit on the adhesive for a bit before it will start coming off easily.
Whatever method you use it may be tedious though.
Old Jul 21, 2006 | 04:10 PM
Dakkerz's Avatar
You can also try 3M adhesive remover
Old Jul 21, 2006 | 04:31 PM
Choonz's Avatar
alright thanks for the tip m8's
Old Jul 21, 2006 | 06:37 PM
BigSash's Avatar
Those tips kind of sucked man. To really advise you I would need to know what and where it is stuck and what it is holding on. But for most applications what yout want to do is:
Heat the tape up before you ever try to pull on it even a little bit.
Get it real hot, like if it had been sitting in the sun for a half an hour then pull it off. you may need a little bit of goo gone for some residue but this method will work.
The key is that you don't try tugging on it ever before heating it up because you don't want to stress the adhesive on particular areas you want it even when you heat it just like when it got put on.
I use this tape a lot and in the summer when it gets around or over 100 degrees if it is in an area exposed to the sun it comes off by itself smooth as a babies bottom.
Old Jul 21, 2006 | 07:27 PM
Choonz's Avatar
welll i need to remove the 3m from my hood, fender and mirrors. btw thanks for the tip
