OFFSET Question
I rolled mine.
I have a friend who works for discount tire direct so they just let me borrow their roller. It is a device that attaches to your hub. You use a heat gun to warm the paint and then just roll this little device on the inside of your fender increasing the angle and pressure as you go. It takes a couple hours when you factor in taking off your wheels and stuff but it is not hard.
That's WAYYYY too much for an 8.5" rim. 35-40 would have an agressive fitment without rubbing.
Originally Posted by codeflux
take it to a body shop to get the fenders rolled. you don't want to crack your paint and have to repaint half the car.
+43 or +45 would be good offset for 8.5" wide rim.
not to hijack but i am wondering on a 8.0 by a + 40 on the front and a 9.0 by a + 38 on the rear?
with 275/35/18 and 245/40/18
or should i go with
265/40/18 and 235/45/18
am I ok can i lower ?
or should i go with
Originally Posted by fokai
can someone explain the process of rolling the fenders. i'm pretty sure i will have to do that because i will be dropped on eibachs pro. do you have to take it somewhere to get rolled or can you do it yourself? thanks.
I don't understand why people insist on buying wheels with the WRONG fitment.
or should i go with
or should i go with
Originally Posted by skeleton_cru
Why not just get the correct offsets???
A lot of times the wheel someone wants is not available in an offset that will fit our car so we have to be very aggressive and try to make it work.
People need to understand that in some cases to get what you want you may need to be willing to make some modifications or find another wheel.
My wheel manufacturer said there was no way a 10" +43 rear wheel would fit on a G35 sedan without rubbing, even if the fenders were rolled. I was able to prove them wrong and I have zero rubbing.
Originally Posted by LuXXXz
chico you seen the Sevas on that blue G sedan and they fit and those were
20x10 w/ a +40 offset
you're still waiting for these wheels? it's been a long time, hasn't it?
chico, im stil fu*ken waiting but i guess they werent available anywhere else as well, they're barely getting made i called sevas and they said next week wednesday they're getting shipped out to stores so im assuming in about a week and ahalf ill have them
Then they're not made for your car. Why not get 8.5 all the way around?
Cru has a point.
Either get the ones for your car or make the necessary adjustments to make them fit.
