So 20x10" wheels do fit on my 2.5" drop. . .
Old Aug 10, 2006 | 03:33 PM
ttrank's Avatar
Grocery getter
Originally Posted by Nickk6
Just rent the fender roller from BIGSASH for $40, its well worth it.
+1
And don't forget the heat gun to keep your paint nice and warm so the clear does not crack.
Old Aug 10, 2006 | 04:03 PM
Nickk6's Avatar
Originally Posted by ttrank
+1
Good call. I also used some paint safe grease, I greased up the fender before heating it, the grease (high temp) saved the paint from any kind of damage. With the heat and roller pushing on the painted surface, the grease helped the tool slide easier.
Old Aug 10, 2006 | 05:04 PM
Neal376's Avatar
no worries, I know someone in the area who owns and uses a roller with heat gun. Greese is a good idea
Old Aug 10, 2006 | 05:17 PM
Diesel1's Avatar
Moderator
I do have a fender roller.....hint hint to Kenny and Neal!
Speaking of which.....Kenny I need an oil change! LOL
Old Aug 10, 2006 | 05:22 PM
Neal376's Avatar
yea kenny! I need a crush washer!
hook a brotha up!
Old Aug 10, 2006 | 05:51 PM
da mayor's Avatar
fast service diesel pulled you in for saturday morning.
neal you'll get a crush washer for your next oil change
as for wheels i might hold off b/c i found a sick apartment i'm looking at with a friend of mine
Old Aug 10, 2006 | 06:54 PM
MI SO FST's Avatar
whats the offset of those wheels anyways?
Old Aug 11, 2006 | 12:31 PM
Neal376's Avatar
-120
Old Aug 11, 2006 | 12:32 PM
da mayor's Avatar
i'm going to put daytons on my car w/ the gold wires
Old Aug 11, 2006 | 12:48 PM
vodkarocket's Avatar
Modded Member
Let me know if need help with the offsets on your Daytona's.
14"x4.5" -14ET has worked really well for me.
Old Aug 11, 2006 | 01:15 PM
ttrank's Avatar
Grocery getter
A G with reverse gold wires.... I just threw up in my mouth!
Old Aug 12, 2006 | 08:09 AM
skeleton_cru's Avatar
Sedan
i know 20x10 will fit on a stock height but remember i have the H&R 350z Race Springs on my sedan. The offset was from a coupe so I'm figuring about a 28-30 offset which yes it stuck out way too much. I might just stick with a 9.5" wheel and 255/30/20 tires
You can run a 10" wide wheel in the rear with the correct offset, which is +54.
Old Aug 12, 2006 | 01:26 PM
da mayor's Avatar
lol someone has to photoshop it w/ a velour roof liner
Old Aug 12, 2006 | 01:44 PM
chobble19's Avatar
Thumbs up
i finally got my fenders rolled at billetdesign and i have absolutely no rubbing on my coupe wheels however i cant imagine having a 10inch on my rear ...even when i had "widetrack" my grand prix 10's completely popped out...
Old Aug 12, 2006 | 01:58 PM
  #30
thommyboy0885's Avatar
2.5" drop??? Way to turn your luxury sports car into a lowrider...
