DIY question - changing coolant and bleeding air
Old Aug 15, 2006 | 03:12 PM
mfung's Avatar
i have "bad" experience with changing coolant (and bleeding air) for an old Nissan. So i want make sure i do the right thing for the G. I have read the manual and have some questions.....
1) do you need to raise the front of the car ? (
2) when you refill coolant to the radiator, the air relief plug should be opened. Do you actually see coolant coming out when you refill the radiator ?
3) in the manual, it says turn the temp lever to HOT. And of course we don't have the temp lever. I guess we just need to set the temp to 80-85 degrees ?
Any other tips will be appreciated...
thanks
Old Aug 15, 2006 | 09:16 PM
ttrank's Avatar
Grocery getter
I had my car up in the air the last time I did a flush.
If you bleed the air out quickly then you will have some coolant come out as well. Not a big deal but try and clean as much of it as you can.
I just filled mine, bleed the air out, started it and let it warm up, let it cool down and check for air, repeat as needed....
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Blakearold
Aug 27, 2015 12:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
