Please confirm if this 350Z suspension is Revised or Unrevised!!
Originally Posted by Gsedan35
Huh?
And part of the Z's suspnension revision is a change to the bump stop and dust sheild's int he rear.
Originally Posted by CFaber
wait, what you're showing in those pics is the FRONT. I was inquiring about the rears. I'm assuming that the rear bump stomp from '06 sport suspension can be reused.
Yes the picture show's front's. Left is oem sedan, right is 350Z. Yes the 06 oem Z dustsheild/bumpstops can be reused.
My intent was to use the 350Z fronts as I received them, fully assembled as removed from a '06 350Z. I hadn't planned to remove my OEM sedan "hats" and reinstall them on the 350Z set-up.
Also, for the rears, I'm going to use the 350Z shocks & springs, but use the OEM sedan bump stops, etc.
Is this correct?
Yes, but in the rear I would use the oem 06 350Z dustsheild and the bumpstops inside them. They are very specifically different and part of the 04.5 350Z suspension revision.
Do you know, specifically, how they differ from my sedan shield and bumpstop?
